what 15'' steelies/interceptors fit MK3 GOLFS??
  • what 15'' steelies/interceptors fit MK3 GOLFS??
    i have a small problem, i need to find some 15s inch steelies for the golf but am unsure what fits?
    gemini?
    toyota yaris?
    do mk3s have 15inch steelies?
    i dont want to have to redrill rims or have spacers if possible.
    any help is much appretiated
    Matt.
    EDIT
    ok i can buy these for 200 with tyres
    off a toyota yaris,
    15s 4x100
    offset and width unclear, but thimk its 5.5 ET 45
    will they fit?
    you need a pcd of 5X100 mate
    you see them up for sale every now and then
    cheap to buy, expensive to modify
    iv got a set on mine but have been widened to 8inch and offset a fair bit
    thats the way you want to go if you want them to look good
    Wide Steelies For Sale
    http://www.vwwatercooled.org.au/foru...ies-76972.html
      Excuse my ignorance, but isn't 5x100 only for VR6 with the remainder being 4x100 in CL/GL?
        my bad vr6 is 5X100 yours would be 4X100 i think
          correct weight, mine is 4x100 not 5x100
            I don't know if they're common but Renault scenic rims will fit but centre bore is 60mm iirc.
              Anyone know if these Yaris ones wil fit or et 45 to high and hit strut?? Also unsure on center bore
                They'll fit easy mate, even if you're on coilovers. Tyres are the correct size for the GL too. Good value with that much tread on the tyres.
                Corolla, Astra, Honda steelies, they'll all work. Only bit of muckin' around that you might have to do is boring out the centrebore. I think the Jap ones would be smaller than 57.1mm. Won't cost much at all.
                Present: Mk3 Golf variant.
                  Any ran Gemini steelies on mk3's ? Would be awesome if they're a straight fit
                    Gemini steelies, how big were they? Most Gemini wheels I've read about have poor brake clearance on Mk1 Golfs.
                      All standard Gemini steelies were 13", I've seen a Gemini running with 15" Holden (Opal in Europe) 15" steelies but I have no idea of how they fit.
                      Chris
                        wheels fit, only issue was the hub needs slight boring as was too small
