Indirect TPMS do not use physical pressure sensors. Indirect TPMS measure the "apparent" air pressure, by monitoring individual wheel rotational speeds, and other signals available outside the tire itself. Most indirect TPMS use the fact that an under-inflated tire has a slightly smaller diameter than a correctly inflated tire and therefore has to rotate at a higher angular velocity to cover the same distance as a correctly inflated tire. Newer developments of indirect TPMS can also detect simultaneous under-inflation in up to all four tires using vibration analysis of individual wheels or analysis of load shift effects during acceleration and/or cornering, which can be realized in software using advanced signal processing techniques. However, the vibration analysis technique requires the use of additional suspension sensors which result in increased complexity and cost of the overall system as long as vertical chassis movements are concerned. That is why most current advanced indirect systems use the spectral content of the wheel speed sensor signals so no additional sensors are needed and the computations can also be carried out by usual processors for example in usual ABS or ESC control units.[citation needed]
Indirect TPMS are realized in software in combination with wheel-speed sensors for anti-lock braking systems, and electronic stability control systems. A disadvantage of indirect TPMS is that the driver must calibrate the system by pushing a reset button on the dashboard via an on-board computer and if this is performed when any tire is in an under inflated condition then the system will not report correctly
