just wandering if its possible to increase the offset on wheels by getting someone to grind down the hubs or something like that? the hubs are heaps beefy, my wheel nuts arent even long enough to get through them. would be wanting to take it from around et35 to et50. are the services available to do this and retain the structural integrity of the wheel?
increased offset by grinding down wheel hub?
Yep, evorobin's right. If the wheel lugs aren't long enough, find longer ones. I did the same when I upgraded, though I could still run my standard lugs.
The lugz will be long enough! if anything too long as he's shaving the hub . . . i would imagine shaving so much so that the bolt will still have full thread inside it'll be fine
jus dnt shave any more! ++ How are you going to shave it anyways?? it'll have to be perfection . . .
You _can_ machine wheels (I've had it done on previous cars)
Or should I say, you can get a professional to get the wheels machined.
Any good wheel and tyre specialist should be able to get it done safely (and legally) - cause you do want to stay insured.
Cost isn't generally too bad.
hehe cant see the harm? though i am no professional . . .
