Tyre load ratings...
  • Tyre load ratings...
    My current tyres are stock Conti CS3's which have a load rating of 95 however looking for new tyres in a 235/35R19 and yet to find any with this rating- Most are a 91. Is this really an issue?
    2010 Passat CC TDI | Sat Nav | RVC | Park Assist | Active Seats | Adaptive Cruise | Fiscon Basic Plus | H&R Sports | 19" Kahn RSC 2-Piece
    95 is a rating of 690kg per tyre. So a GVM of 2760
    91 is 600.- GVM 2400
    What does your handbook say? Technically it's illegal to downgrade.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
      I'm flicking through the manual now however it's fairly generic. Also looking if its mentioned somewhere on the car...
      The GVM of the car is 2090kgs so 91 rated tyres 'should' be sufficient...
        Firstly, there is no such thing as a 235/35 R19 tyre with a load rating of 95. It's load index for "standard load" and "extra load" is 87 and 91 respectively, as you have found out.
        Secondly, I believe the homologated tyre sizes for the Passat CC are;
        235/45 R17 94W
        235/40 R18 95Y XL
        235/35 R19 91Y XL
        So even though the load index is less than 95, I would assume a Passat CC optioned with 19" wheels would come with 235/35 R19 91Y XL tyres wrapped around them.
        What you need to do now is to visit a dealer and see if they have any Passat CC's with 19" wheels and see what the load rating is, to confirm my theory. If true, then you shouldn't have any issues fitting them legally.
          Great info guys, thanks very much.
            minimum load rating should be stated on the tyre placard on the fuel flap
              That's where it is... Cheers Brad...
                sorry to revive an old thread, but i am trying to get my head around load ratings for a passat r36. i want to go to 19 inch, but cannot find tyres in 235/35/19 with 95Y rating. How would I find out if the 235/35 R19 91Y XL would be satisfactory (legal) on a r36 wagon?
                  std load on a 235/35x19 is 87 (1200LB); 91 (1356LB) is the extra load (ie, it isn't 91 (1356LB) plus an extra load of XXLB)
                    thanks brad....logic suggest that what's good for the passat CC should be fine for the r36...
                      How many seats is the CC compared to R36? What is the kg boot/load capacity of the two?
                        I just changed my R36 from the standard 235 x 40 x 18 with 95 to 255 x 35 x 19 96. Tyresome in Darlinghurst is very recommended and the one thing they did say is that if you go below the 95 and you have some sort of accident then insurance companies can go to town on you if they find out. Just letting you know what i got told. The one thing they said was that maybe the car being heavy and AWD might be the reason for needed 95. The other thing is it is hard to get a reasonably priced good spec tyre in this weight of 95. i ended up with Michelin pilot sports but i wanted max grip..
                          I assume 235/35 R19 91Y XL is the homologated size for the optional "Omanyt" 8J x 19 wheels, since that's what's shown on the German sales brochures. So as long as you trust VW's judgement, no technical reason should deter you in fitting these tyres.
                          However, since a standard R36 comes with 235/40 R18 95Y XL tyres, and not 235/40 R18 91Y tyres, I assume the Australian tyre placard won't permit tyres with a load index of less than 95.
                          This would mean pinching a tyre placard (don't do that ) from a R36 or CC with factory-ordered 19" wheels, because I assume these vehicles would then come with a tyre placard that permits tyres with a load index "not less than 91". Maybe you could get them from a dealer???
                          You know, they really ought to update the Aussie tyre placards to include the homologated tyre size and load index for plus fitments.
                          Edit - if you plan on buying 255/35 R19 96Y XL tyres, it is recommended you fit them on 8.5J x 19 wheels or wider.
                            Did you end up finding 95 rated tyres? If so how much? I'm looking to upgrade to 19"
                            2010 Passat CC TDI - Sat Nav, Panoramic Roof, Park Assist, Climate Controlled Seats, MDI, Reflex Silver, Kufatec Bluetooth.
                            2012 BMW 328 ///M Sport - Alpine white, Sunroof, Navigation, Bi xenon, extended connectivity package, 19" ///M Sport alloys, ///M Sport package
                              I was curious on exactly how much an R36 weighed, so I did some research...
                              Code:
                                                          R36        R36        CC V6
                                                          Sedan      Wagon      4MOTION
                              Weight (1)                  1736 kg    1800 kg    1702 kg
                              Maximum weight              2270 kg    2350 kg    2130 kg
                              Payload (2)                  609 kg     625 kg     503 kg
                              Maximum front axle load     1170 kg    1170 kg    1160 kg
                              Maximum rear axle load      1150 kg    1230 kg    1020 kg
                              (1) Includes 68 kg driver, 7 kg of luggage, and fuel tank
                                  filled to 90% capacity as per EU directive 92/21/ECC.
                              (2) Payload includes 68 kg driver and 7 kg of luggage.
                              Figures complied from Passat R36 brochure (in German) dated 05/11/2009
                              Now, for a vehicle weighing more than 1.7 tonnes, a load index of 91 might be deficient, so I did some more research...
                              Code:
                              Load capacity at various inflation pressures for EXTRA LOAD tyres with a load index of 91
                              Inflation pressure (bar)   1.9   2.0   2.1   2.2   2.3   2.4   2.5   2.6   2.7   2.8   2.9
                              Load capacity (kg)         440   455   475   495   510   530   545   565   580   600   615
                              Okay, so it turns out that 615 kg x 2 = 1230 kg per axle is not deficient (strictly speaking!) but only if the tyre is inflated to 2.9 bar (42 psi). Note that this has nothing to do with the maximum pressure of 3.5 bar (51 psi) that's indicated on the tyre sidewall.
                              This means that:
                              A maximum front axle load of 1170 kg would leave a margin of less than 5%.
                              A maximum rear axle load of 1150 kg (sedan) would leave a margin of less than 7%.
                              A maximum rear axle load of 1230 kg (wagon) would leave a margin of 0%.
                              This assumes the owner is vigilant in maintaining the inflation pressure at 2.9 bar (42 psi) and correctly calibrating the TPMS because these margins will only decrease further if the inflation pressure falls, unless the payload is reduced.
                              So in conclusion, pay careful attention to the tyre placard, never inflate below the recommended inflation pressures, and remember that the maximum load capacity for any XL tyre is only reached at 2.9 bar (42 psi).
