I have a Polo GTI, since buying it a year ago, I'm on my 3rd set of rims (I like to play).
I noticed going from the OEM 16's with Conti' CCS2's to the VW Siata 17's with Kumho KU31's that the traction was improved. It was difficult to say much about the change as the unsprung weight, rims and tyres all changed.
Recently I changed from the Siata rims to some Audi TT rims. I had the existing tyres put on the new rims.
Since using my new rims, I've noticed a definite improvement in the cornering. I'm trying to understand why.
Here is a little data:
Siata rims (Old):
Width: 7"
Offset: 38
Weight: Around 8kgs
Audi TT rims (New):
Width: 7.5"
Offset: 32
Weight: Around 12kgs
So the obvious differences are:
- Wider Rims (but same rubber)
- Heavier Rims
- Lower offset (Wider stance)
The distance from wheel center to center has only increased by 12mm total. This is not a lot, not even a 1% change in the overall track width. The wheel being further from the suspension will have an effect on the way the spring / shock is worked and for lack of a better way to put it, the load on one side of the fulcrum has changed.
The weight of the rims adding to the unsprung weight can make the car handle worse, but feels like it works more compliantly with my stiff suspension setup. I'm running coilovers, sways and whiteline bushes.
The rubber being stretched a little more across the rim could change the way the tread meets the road. Someone said the tread could have opened up a little more, but I'm not sure.
The tyres are 205/40/17 and are suitable for both rim widths.
All these small changes affect the way the car handles. Does anyone have some understanding or experience as to which of these changes is making the bulk of the difference in improving the handling, or is it something I've missed?
Siata rims (Old):
Width: 7"
Offset: 38
Weight: Around 8kgs
Audi TT rims (New):
Width: 7.5"
Offset: 32
- Heavier Rims
