Scirocco mk 2 dilemma wheels
  • Scirocco mk 2 dilemma wheels
    i bought wheels and realized they are not matching any ideas i have
    3x 4x100 16x7.5 ET35
    1 4x100 16x7.5 ET40
    standard wheels are 14x5.5 et38
    i got them from neale wheels have emailed them to see if they will do something about it. looking for ideas
    5mm spacer for the ET40 should fix the problem????
      Or see if you can get 5mm shaved off the back of the et40 wheel
        Wouldn't that make it ET45 as it will sit further inwards then?
          offset
          neale wheels said they would fix giving me offset of 35
          that brings the wheels 15mm towards hub and 20mil toward the gaurd i might barr the wheels that sounds like alot
          and yes machining increases the offset which is wrong direction 35 may still be a problem and im wondering how neale said they will fix it ill post how they do this when they do
            Woops your right, its too early!
              shave 5mm off the 3 ET35 wheels..
