When installing a lower stress bar (front) does the car need to be suspended and weight taken off the front wheels? or would I be ok installing this on ramps?
MK2 Lower Stress Bar (Front)
id get the weight off the control arms if that is your mounting point. Usually you need to remove the main bolt that they pivot on.
On most of the cars ive fitted one we got the car on stands. On some cars you need to undo engine mounts and lift the engine a little as well so the control arm bolt on one side can clear the sump.
FOLLOW US ON FACEBOOK
