plug and redrill
  • plug and redrill
    whats the go with plugging wheels and re drilling to a new offset? so far I can't find any reason that this can't be done. is it in some way unsafe?
    also going to ask here can you shave the back of a wheel to get a larger offset? obviously there is a limit to how much you can shave but has anyone done this before?
    Originally posted by Preen59
    its all dependant on the design of the wheel. You really need to get them inspected by a wheel repair/engineering place to see if they think theyre safe.
    For example shaving material off the mounting face is possible depending on the thickness/composition of that material. I think dom also had some material shaved off his centres where the outer lip mounts to gain a mm or 2.
    FOLLOW US ON FACEBOOK
      As Tim said. To elaborate, if you're redrilling from a 4 stud to a 5 stud (or vice versa), make sure the hub is flat and not ribbed/flower-shaped. I had a set of wheels that had its original 5x114.3 plugged, and redrilled 4x100. I had no problems, drove the same as with OEM or other wheels. Hub was flat-backed, and there was enough room to accomodate a smaller PCD. Which leads me to my next point - if you're redrilling to a smaller PCD, sometimes it may not be best as it drills in too close to the edge of the centrebore, or any other thing towards the middle. I couldn't redrill my BBS RSIIs as it would have took out some of the centrecap screw thread. Not impossible, but it would've been undesirable as I wouldn't be able to run centrecaps. Just talk to a wheel guy about it.
      Present: Mk3 Golf variant.
        okay cool thanks
        and now too look like a noob,
        I thought you could just straight out redrill on flat backed wheels you just drilled in the space between the original PCD only need to plug where the old PCD would intersect with the new PCD.
        And I thought with plug and re-drill it would let me re-drill on a ribbed/flower shape back over the top of the old PCD.
        trying to keep as big of an offset as I can to run wider lips on these RS.
        all going to go from 5x114.3 to 5x100
        The ribs on one set are only like 6mm deep so was hoping to to shave that off completely and then redrill
        center bore on one set 61 and the other is like 67.
        Guess I'll just run them down to the wheel guys and see what they say.
          hmm let me know what you find out, seems like we are in the same boat.
          Bora gone
          Vento VR6
          MKIV GSW TDI
          7P Touareg TDI
            plug and re-drill
            I'm also in the same boat, i talked and emailed these guy's here:
            and they were really nice (but in lillydale which is quite far from me, although courier is cheap)
            my wheels have had someone drill them out i think so there is no "flange" on the 4 x 100 bolt holes....i was quoted 50 per corner which i reckon is pretty good, be happier if there was a place close to melbourne though...
            Current ride - MKVI GTI, Candy White, 4 door, Detroits, DSG, BT
            Previous VW - MK 1 Golf Clipper Convertible - 1993 - gone and now called Linda
            Previous VW - MK 1 Golf GTI 1983, Lhasa Green, Perrielli P's, euro front look, gone but not forgotten
              I used these guys for my MOMOs they are good but costly
              http://www.advancedalloys.com.au/home/
              in Moorabbin so still not in the city but closer than Lillydale
