Quick Offset Question
  • Quick Offset Question
    Hi,
    I am looking at getting a new set of rims for my mk4 golf gti. Currently the car has stock gti alloy rims on it but i have been searching ebay and have found a set of audi tt rims 5x100 with 32mm offset.
    Basically my question is, will these rims fit my car as i don't know a heap about cars etc
    Any help would be appreciated
    the width of the rims makes a difference as well.
    If you know the specs of your stock rims you can use this calculator to compare
    FOLLOW US ON FACEBOOK
      To the best of my knowledge, 16" TT rims are a direct bolt on to the MKIV.
        Yep, and the 17s as well.
        Nothing to see here...
          http://www.1010tires.com/WheelOffsetCalculator.asp
          As Tim said, the width makes a difference, pretty sure the TT wheels will be 7.5 wide with a 32 offset. What wheels are on your car at the moment?
          Bora gone
          Vento VR6
          MKIV GSW TDI
          7P Touareg TDI
            I have the stock GTI, well what i think are stock gti rims.
            Hmm i am not looking at these http://www.ecstuning.com/Volkswagen-...321/ES1884321/ would i have any problem with these rims/tyres or should i totally scrap the idea and just get some rims from tempe tyres lol
              im not sure of the specs of those rims, but id say the TTs would fit.
              The TTs on my car come out closer to the arches so id say they would be the same on your GTI, there a nice looking rim on MK4s
              Bora gone
              Vento VR6
              MKIV GSW TDI
              7P Touareg TDI
                The Mk1 TT does share the same 5x100 bolt pattern as the Mk4, every OEM Mk1 TT wheel should be a direct bolt on to the Mk4 platform. The TT used slightly lower offsets (et's in the mid 30's), but it shouldn't cause any issues on the Mk4.
                  Originally posted by Xcom View Post
                  Hi,
                  Simple Answer? Yes. I have 17" 32mm (I think, from memory...) offset TT wheels on mine, 7 spokers that I got from ECS.
