I had the same rear caliper type on my previous car...I just used Circlip Pliers to wind in the rear pistons.
Brake Pad Replacement
I have recently been made aware of this push and rotate procedure.
Is this required for both front and rear brakes ?
and in particular for Passat 1.8t 1999 and Golf Gti 2007 (both fuel).
Question without notice :
If the piston has to be pushed back (of course) and rotated for the assembly of new pads, why doesn`t the piston jam during braking, does it really unscrew against the brake pad when pressure is applied ???
Regards John
We just make one ourselves as we wear out one every 6 months.It doesn't have to look pretty,it just has to work.Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
Just the back brakes for the tool. You need to set the cutouts across the caliper, parallel with the road. Then the piston ratchets out as the pads wear.Originally posted by johnvw View PostI have recently been made aware of this push and rotate procedure.
Regards John
Front just pushed back in.
GAvin
