My wheel stud conversion kit finally arrived from Motorsport hardware. When fitting the wheel studs (M14) is there a recommended torque spec for seating? Do I need a dab of loctite too?
Advice on Seating wheel studs
long nosed with allen key fitment. A shoulder between the seated part and the actual stud that the rim fits on.
82mm Black Bullet Nose Race Stud Kit 14x1.5 - Motorsport Hardware
50ft/lb is only 68Nm. The wheel bolts are usually 120Nm aren't they? I'd go at least to that with a dab of loktite.carandimage The place where Off-Topic is On-Topic
Tis too on reflection was my Landcruiser mags? that were only 90 Checked the torque wrench in my boot and its set at 120Originally posted by brad View PostGolfs 120Nm - which isn't very tight.2021 Kamiq LE 110 , Moon White, BV cameras F & B
