Always brush and detergent. Swap the brake pads for ceramic brake pads and you can throw away brush.
Transporter is spot on
Thats what rating i give ceramic pads will never go back to black dust oem
2017 Golf Alltrack 135tdi All options
I used the Meguiar's spray bottle wheel cleaner on my factory 16s, worked amazingly well for the hardened dust. It's some kind of acid - you need to keep it away from the calipers.
I'm sticking with the OEM pads. They put out a lot of dust but they never squeal and I think they're pretty easy on the rotors.
You'll go through a set of rotors to a set of OEM pads. It's not the pads. it's the soft rotors.
carandimage The place where Off-Topic is On-Topic I used to think I was anal-retentive until I started getting involved in car forums
