Originally posted by ope126
View Post
2 Channel Dash Cam with Parking Mode - Thinkware, Blackview or iRoad
Originally posted by Hillbilly View PostAll the LEDs on my cameras are turned off always
Is there a way to turn that off (I assume you have to turn the Wi-Fi Direct off permanently for that)?
Or does it turn off when the REC and GPS LED's are off too.MY18 VW Passat Alltrack Wolfsburg Edition + Panoramic Sunroof + some extra goodies... (Pure White)
If i need to look at them I put the SD card in my PC and look or save what I want Cant stand waiting for tiny phone screen to buffer endlessly. If needed I can turn the Wifi on to show a cop if needed.
Am not into looking at uninteresting footage or making Youtube videos.Last edited by Guest001; 17-06-2017, 02:15 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
I ordered the package that included a 64GB PITTASOFT (BlackVue) SD Card.
If you do a little research they are MLC SD Cards, so are pretty good and definatley suited to Dashcams; https://www.blackvue.com.au/product/accessories/
I was actually going to purchase a Lexar 633X 64GB SD Card, but as mentioned the deal cam with a genuine SD Card.
Here is a link to get one for $55; Lexar High-Performance microSDXC UHS-I 64GB - 95MB/sMY18 VW Passat Alltrack Wolfsburg Edition + Panoramic Sunroof + some extra goodies... (Pure White)
Originally posted by pandas View PostWhat sized microSD card are you using ? Do you get much footage out of it and are you using a genuine Blackvue or 3rd party? Considering getting a 64gb, a Lexar high endurance will cost $50 whereas a genuine blackvue would be $20 more.
Sandisk is a 128Gb UHS-/1Class 10 ONLY BUY OFF AMAZON proper NOT AMAZON SELLERS
If you format them correctly they will work in older models as well Like the DR400 in my wifes car.
Blackvue are like Aldi they dont make the stuff so get rebranded ones off some factoryLast edited by Guest001; 17-06-2017, 07:12 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Finally got around to installing the front cam. A infant and a toddler just doesn't mix well with personal time.
Hillbilly, I noticed from another thread you used some sort of a clip to install the rear dash cam. Where did u get that clip / mount as it appears to be an easy way around mounting the rear.
Also ended up purchasing a genuine blackvue 64gb. Didn't want to play around with other brands as the 650 appears to be quite picky.
Originally posted by pandas View PostFinally got around to installing the front cam. A infant and a toddler just doesn't mix well with personal time.
Was easier to do what I did than try and get the cable through onto the taildoor.
Did that on my Landcruiser and needed some personal lubricant to get the cable end through the rubber connector to the door2021 Kamiq LE 110 , Moon White, BV cameras F & B
