Hey all,
I have a quick query about bluetooth, headunit and car generation compatibility, sorry about that. I know this gets talked about to no end, I'm just chasing my tail trying to track down some definitive information.
I've just bought my first VW, a my08 Jetta with a full height red MFD. I also have a 5K0 035 190 A (Bosch) RCD510 headunit to replace the installed RCD300.
Basically I'd like to install the bluetooth module with the most modern functionality I can utilize... so am I right in saying:
Also are the battery drain problems definitively fixed with the my08 full height red MFD?
Any information would be greatly appreciated.
Cheers,
Walter
- 9w2 Calls and music streaming, should work with full functionality.
- 9w3 Is this available in Australia?
- 9w7 Same as 9w2 but displays phonebook and allows calls to be made from the headunit. (Unsure if this works on red MFD units or requires more modern cars with white MFD). I'd quite like this function if I can.
- 9wz Most modern unit, unsure if it's compatible.
Cheers,
Walter
