Hi All,
We are offering a special group buy offer to VWWatercooled Forum Members
We have made a YouTube video of it in action:
[YOUTUBE]QpWMsgGVnds[/YOUTUBE]
Well get to the point, how much is it?
$345.00 inclusive of shipping Australia Wide
Confirmed Members
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Group Buy Pricing Valid Until Sunday 12 March 2017
What is PolarFIS Advanced?
PolarFIS Advanced is a electronic device oriented to the VAG vehicle market. This device allows you to visualize very important engine parameters “hidden” in your car. You only need to connect the device easily inside your vehicle and you will start to monitorize all you desire in real time.
Currently are supported near 140 engine parameters, depending of the model of vehicle.
Other Extra Functions Ready To Use
OTHER EXTRA FUNCTIONS READY TO USE
1.- TV-Free function to see video in motion
2.- Battery drain fix for vehicles equipped with RNS-510 and old gateways before index “K”
3.- Parktronic OPS emulation function (see Parktronic screen in RNS510 with Parktronic PDC ecu) (only available with Skoda vehicles)
4.- Confort blinkers configurables from 3 to 10 blinks
5.- Mirror lowering function (passenger mirror goes down to a configured position when engage reverse gear)
6.- Add BT Hands free compatibility with White dot Hands free units (Can works with all models of BT for white dot cars up to this date)
7.- Activation / deactivation of RNS-510 hidden menu
8.- DIAG : 1 – Adjust sensibility percentage automatic wiper
9.- DIAG : 2 – Adjust sensibility percentage automatic lights
10.- DIAG : 3 – Activation/Deact. Daytime running lights
11.- DIAG : 4 – Activation/Deact. cornering lights
12.- DIAG : 5 – Activation/Deact. american lights
13.- DIAG : 6 – Activation/Deact. cornering lights
14.- DIAG : 7 – Activation/Deact. warning lights (blinkers)
15.- DIAG : 8 – Activation/Deact. of second rear fog light
16.- DIAG : 9 – Activation/Deact. windows automatic rain closing
17.- DIAG : 10 – Activation/Deact. automatic closing at 20 Kmh
18.- DIAG : 11 – Activation/Deact. one touch closing
Which Vehicles Are Supported?
AUDI
Audi A3 8P red_dot / white_dot
Audi S3 8P red_dot / white_dot
Audi S3 Sportback 8P red_dot / white_dot
Audi RS3 8P red_dot / white_dot
VOLKSWAGEN
Volkswagen Golf Mk5 (1K) red_dot
Volkswagen Golf Mk6 (5K) white_dot
Volkswagen Jetta Mk5 (1K) red_dot
Volkswagen Jetta Mk6 (5C) white_dot
Volkswagen Caddy (2K) red_dot
Volkswagen Caddy (2C) white_dot
Volkswagen Tiguan (5N) red_dot / white_dot
Volkswagen Touran (1T) red_dot / white_dot
Volkswagen EOS (1F) red_dot / white_dot
Volkswagen Passat (3C) red_dot / white_dot
Volkswagen Passat (36) white_dot
Volkswagen Passat CC (35) white_dot
Volkswagen Scirocco (13) red_dot / white_dot
Volkswagen Sharan (7N) white_dot
SKODA
Skoda Octavia II / Octavia II FL (1Z) red_dot / white_dot
Skoda Superb II (3T) white_dot
SEAT
Seat Leon II & Seat Leon II FL (1P) red_dot / white_dot
Seat Alhambra (7N) white_dot
Seat Altea, AlteaXL & AlteaFreetrack (5P) red_dot / white_dot
Seat Toledo (5P) red_dot / white_dot
Paramaters Supported
1.- Real speed
2.- External temperature
3.- RPM motor
4.- Battery voltage
5.- Petrol tank litres
6.- Calculated oil temperature
7.- Measured oil temperature
8.- Engine ambient temperature
9.- Admision temperature
10.- Cooler temperature
11.- Engine coolant output temp.
12.- Radiator coolant output temp.
13.- Oil temperature
14.- Requested boost pressure
15.- Measured boost pressure
16.- Atmospheric pressure
17.- Intake manifold absolute pressure
18.- Required fuel pump pressure
19.- Measured fuel pump pressure
20.- Fuel rail pressure
21.- Brake pedal pressure
22.- Brake pump pressure
23.- Calculated engine load
24.- Measured engine load
25.- Mass air flow
26.- Mass air flow
27.- Acelerator pedal position
28.- Acelerator pedal position
29.- Acelerator valve position
30.- Acelerator valve position
31.- Engine torque
32.- Engine power (CV)
33.- Level oil
34.- Minimun level oil
35.- Injection timing
36.- Ignition angle
37.- Misfire sum
38.- Misfire cylinder 1
39.- Misfire cylinder 2
40.- Misfire cylinder 3
41.- Misfire cylinder 4
42.- Misfire cylinder 5
43.- Misfire cylinder 6
44.- Misfire cylinder 7
45.- Misfire cylinder 8
46.- Misfire cylinder 9
47.- Misfire cylinder 10
48.- Misfire cylinder 11
49.- Misfire cylinder 12
50.- Misfire cylinder 1
51.- Misfire cylinder 2
52.- Misfire cylinder 3
53.- Misfire cylinder 4
54.- Misfire cylinder 5
55.- Misfire cylinder 6
56.- Misfire cylinder 7
57.- Misfire cylinder 8
58.- Misfire cylinder 9
59.- Misfire cylinder 10
60.- Misfire cylinder 11
61.- Misfire cylinder 12
62.- Angle delay cylinder 1
63.- Angle delay cylinder 2
64.- Angle delay cylinder 3
65.- Angle delay cylinder 4
66.- Angle delay cylinder 5
67.- Angle delay cylinder 6
68.- Angle delay cylinder 7
69.- Angle delay cylinder 8
70.- Angle delay cylinder 9
71.- Angle delay cylinder 10
72.- Angle delay cylinder 11
73.- Angle delay cylinder 12
74.- Escape temperature
75.- Escape temperature
76.- Catalyzer input temperature
77.- AFR (air / flow ratio) Lambda 1
78.- AFR (air / flow ratio) Lambda 2
79.- Fuel trim bank 1/3
80.- Fuel trim bank 2/4
81.- N75 duty cycle specified
82.- N75 duty cycle actual
83.- Injection quantity
84.- Injection start
85.- Injection duration
86.- Injection start quantity
87.- Injection quantity 1
88.- Injection quantity 2
89.- Injection quantity 3
90.- Injection quantity 4
91.- Injection quantity 5
92.- Injection quantity 6
93.- Injection quantity 7
94.- Injection quantity 8
95.- Injection quantity 9
96.- Injection quantity 10
97.- Injection quantity 11
98.- Injection quantity 12
99.- EGR duty cycle, EGR 1
100.- EGR duty cycle, EGR 2
101.- Chargue pressure control Specified
102.- Chargue pressure control Actual
103.- Temperature prior bost
104.- DPF temperature, DPF 1
105.- DPF temperature, DPF 2
106.- DPF oil Ash Volume, DPF 1
107.- DPF oil Ash Volume, DPF 2
108.- DPF filling
109.- DPF regen counter
110.- DPF input temperature
111.- DPF output temperature
112.- Lateral G-Aceleration
113.- DPF Kms. since last regen
114.- AD-Blue filling (%)
115.- AD-Blue used (grs.)
116.- Rail pressure requested
117.- Injection duration requested
118.- Injection start requested
119.- Lambda calculated diesel motor
120.- DPF filling calculated
121.- DPF regen status
122.- DPF Direfential pressure
123.- Particle filter measured soot mass
124.- Particle filter measured soot mass
125.- Particle filter calculated soot mass
126.- Particle filter calculated soot mass
127.- Lambda adaptation idle (%)
128.- Lambda adaptation idle (%)
129.- Lambda adaptation partial (%)
130.- Lambda adaptation partial (%)
131.- Exhaust gas temperature sensor 1
132.- Exhaust gas temperature sensor 2
133.- Exhaust gas temperature sensor 3
134.- Exhaust gas temperature sensor 4
135.- ASR torque requested
136.- Torque redution requested by ESP
137.- Torque limitation
138.- Requested regenerations
139.- Generator load (%)
140.- Alternator power (Watt)
141.- Rear fuel pump pressure
142.- Rear fuel pump duty cycle
143.- Compressor torque
144.- A/C pressure
Confirmed Members
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
AUDI
VOLKSWAGEN
SKODA
SEAT
1.- Real speed
3.- RPM motor
4.- Battery voltage
25.- Mass air flow
26.- Mass air flow
31.- Engine torque
33.- Level oil
36.- Ignition angle
37.- Misfire sum
108.- DPF filling
144.- A/C pressure
