Hi all, just wanted to clarify a things.
I've currently got an 06 Golf MK5, and am thinking of upgrading the head unit to the RCD510.
Already read many posts about the install and such, including the need for a new canbus L revision module, however I've also read that there is a simple bypass via the fusebox.
(more info here: A tested and proven quick fix for rcd510/rns510 power drain - page 1 - How to Guides / Troubleshooting - MK5 Golf GTI )
My question is, if I were to do a DIY Install of the RCD510, using the fusebox bypass, would I still need to use VCDS/Recoding to get it to work?
Many thanks!
Many thanks!
