Hi all,
I had some questions that i couldn't find using search there as are a huge number of results.
I have a VW 2005 Golf Mk5 1.9 TDI
It has a RED MFD screen (Between tach and speedo)
It currently has an RCD300 ultra basic Head unit installed.
I recently purchased a used original RCD510
After my reading, i understand to install the RCD510 i believe i need to update the canbus module. BUT it must be the correct one for a RED MFD that can have a bluetooth device installed. I have no idea which is the correct Canbus module for this car and this head unit that accepts bluetooth with A2DP and connection to my iphone5 and iphone6. Ideally i want to display caller info on the headunit and a wish on the MFD.
I really like the Fiscon Basic bluetooth thingy though it is expensive.
So my questions are as follows for the VW Audio gurus out there.
What canbus should i use on my car (Part No.)
Will the 9w7 bluetooth unit do the job as above with the correct canbus?
Will the Fiscon basic bluetooth thingy be better as eventually i want to do an upgrade to an RNS510
Lastly i have an alpine amp and 4 great speakers to install after the headunit upgrade. Should i do any prep work while im doing the Headunit or is there things i should look out for.
Trumper
Trumper
