I am no expert here so after alot of reading in the VW Audio lounge i just wanted to confirm what i think i have decided based on what ive read.
I have the RNS-510 in a MK5 GT Sport, no factory amp.
After reading about the MK4 speakers i am presuming the MK5 speakers are pretty good quality and if i add an amp to the system it will give me a big improvement.
My thoughts are to add a 4ch amp that has a pass through (i think thats what its called) so that later i can go out from this amp into another one to run a subwoofer.
I am looking at this amp from Jaycar.
Does this sound like an ok setup.?
I have read alot about only running the front speakers through an amp and leaving the rears on the HU but in doing this it would mean that i would need a LOC for the fronts as the RNS-510 would still need to be set to speaker outputs. (Using VAG-COM the RNS-510 can be set to line out outputs)
This would also mean that later when i want to install an amp it would be a little more difficult as i should feed the SW amp from the rear outputs.
Am i correct.
What do you experts think of my very basic idea of the 4ch amp on all 4 speakers.
Thanks guys for your help.
Am i correct.
