Have other users noticed what a poor manual comes with the Mk7? — not even near the set supplied with the Mk6.
Not only is it often tedious to make sense of, in places it's not even accurate.
Today I had occasion to look at the internal fuse box (Page 365) and failed to find it.
Read the section in the manual, which tells you it's behind the right-hand storage bin, which you remove by releasing two clips at the bottom whilst pulling the bin out (sounds like it'd need three hands, but I s'pose it's possible.)
Opened it, no clips to be seen.
Then noticed the picture of the left-hand drive bin matched the one in mine, so followed the procedure for that and it pulled out much like the Mk 6 one did.
Only one problem — no fuse box, just a gaping hole.
Before I dismantle the car, does anyone know where the Mk 7 Highline internal fuse box lives?
Reason for asking — I've been given a HUD to play with and its power cable isn't long enough to reach the 12V outlet in the centre console if I route it neatly and clear of my feet, so thought to run a lead from the fuse box.
If the fuse box is where the book says LH drive cars have it, that might not work either (at least, not easily.)
I found I can also power it from the USB port in front of the gearshift, but then can't close the lid — nothing's simple any more...
