VW map update for RNS510
    [I@ Mantis:- If you check the region code in your unit, you may find it has reverted to its factory setting.
    Mine (installed by Barloworld prior to delivery) thought it was in China and wouldn't play most legal discs — home burnt ones without region code were fine.
    Barloworld at that time (2009) didn't know how to fix it (or didn't want to, said they'd let me know but I heard no more from them) — had to do it myself (easy with VCDS.)
      Hmmm, so chances are a simple firmware update won't fix it....
      What is the VCDS you speak of? I'm pretty new to the whole VW jargon, ask me anything related to a Subaru and I'm in my comfort zone, but speaking VW is a totally different language to me.
        RE: VW map update for RNS510
        Vcds consists of a cable and program from ross-tech.com It plugs into the connector above the accelerator and lets you set the modules and systems in the car. It also lets you see fault codes and reset them. If you set DVD region to 0 you can play any DVD.
        Sent from my RM-821_apac_australia_new_zealand_304 using Board Express
        08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
        http://photobucket.com/gregsr32
          See here: http://www.vwwatercooled.com/forums/...dex-65460.html
          And here: http://www.vwwatercooled.com/forums/...ary-50749.html
          Regards
          Ryan
          Audi A3
