Not really audio-related but my application is, and most of the wiring/electrical gurus are in here. I want to relocate my battery to the boot where it's closer to the amplifier I'll be hooking up. I thought it was a good idea anyway as relocating to the boot yields many advantages (weight distribution, more space in the engine bay, less wiring) and by using maintenance-free batteries, I wouldn't have to worry about gas build-up or acid spills.
So what's really involved? I've been looking up some info and guides on the internet but like most guides, they explain everything as if you already understand how it all works - I don't
So my question for now is, (1) how is the battery hooked up? Where do the wires connected to the negative and positive terminals go? I have a faint idea that the negative is connected to the chassis/frame (ground), and the positive is hooked up to the engine, but I see a one or two other wires. Where else do they go, and for what purpose?
My problems are understanding those points and knowing what other components do (distribution block, circuit breakers, different gauge wires etc). I'll ask questions on those once I understand the first bit! Doing the actual install in the boot I'm confident with though.
In need of knowledge! Cheers.
