I need duff duff
  • #16
    Here's an explanation of the speaker setups, in a nutshell
    All headunits have RCA Pre-outs. These are the outputs which run to your speakers that make them PLAY SOUND! Most headunits have 4 RCA Pre-outs which means you can run four seperate speakers. However as for some of the more special headunits, i THINK they can come with more pre-outs (i THINK..).
    As for speakers, you get all the different types -the tweeters, the woofers (most speakers are these), or the splits (which are speakers with two or more separate speakers - mostly the woofer/tweeter set-up). Most speakers are simple and come as one piece; BUT, for some types of splits, the tweeters can be mounted separately. This is still essentially "one speaker" because the high/low frequencies are split up into the different speakers (tweeter/woofer respectively) for better sound efficiency.
    To wire up speakers in a car, most people use one line per speaker. The pre-outs are almost always used in 4-ohm mode, which is just normal and is NOT worth explaining. Some headunits come with more options such as a 2-ohm mode. With 2-ohms, you can run "double the power", and therefore hook up two speakers to one line, but you have to "halve" the speaker ohmage, from 4-ohms to 8-ohms, so all the ohmage stuff matches up (the higher the ohms the lower the 'power' - ...it's complicated stuff..). It works well, especially for people like me who want a temporary fix to 6 speakers, a sub, and only one four-channel amp
    SO. If you personally would like to play 6 speakers at once, and if you include the tweeters used in the dash as separate speakers, then yes it is possible to wire these up with a normal headunit (and it's recommended! I did it too - cheaper, and better sound - better than more speakers, because the high frequency sounds that come from speakers are more directional [and should be put higher - e.g dash, door cards]).
    If however you want 6 SEPARATE sets of speakers, then you will need either a headunit with 6 pre-outs, or an amp. And naturally I would suggest the amp because you can plug more speakers into the amp and then it sounds awesome!
    Hope this helps Water_Boy! Sorry if it's confusing..i've been reading about all this for ages as I'm really into car sound. My cuz and I are about to make a fiberglass mould for my sub just like Louis did! Yay for sound!
    • #17
      Eeeek!
      RCA Pre-Outs are audio outputs that you connect to external amplifiers.
      The RCA leads carry the audio signal to the amplifier. The amplifier then powers the speakers.
      Most headunits (HU) have 4x faded RCA Pre-outs (Front L+R and Rear L+R). Faded so as you can balance the sound front to rear and left to right.
      Some Head units also have an aditional 2x Non-faded Sub RCA Pre-out (L+R) Which will bring total to 6 Pre-out RCA.
      Also make note of the RCA Voltage output.
      Crappy HU are <2V, You should get a HU with at least 2V Pre-out, 4V is better and some HU now come with 6V and rarely 8V. Make sure that the Amplifiers you choose will work with the HU RCA voltage...
      Most Clarion HU are 4V, and I think this is becomming the common RCA voltage output.
      Why... The higher the RCA Voltage the easier it is for you amplifier to amplify the audio output.
      eg 2V RCA vs 4V RCA into same AMP at same HU sound level = 4V should be twice as loud!
      A reason behind this is to reduce noise that might be introduced into the RCA leads from being amplified. 4V RCA will have less 'Signal to noise ratio' than 2V if the same noise is introduced into the RCA.
      But a main reason is that the amp will run cooler and use less battery current as it not working as hard for the same sound level you hear.
      There are 3 types of speakers.
      1) Most standard is the coaxial where the tweeter is mounted in front of the woofer cone and it is basically considered 1 speaker.
      2) Splits where the woofer and tweeter (and in some cases a mid-range) are separate speakers all connected to a crossover that splits the audio frequencies to the correct speakers. Splits are used to bring the high range audio from the tweeters closer to the listeners ears as high range audio is directional... you dont want tweeter firing from the door straight at your feet as your feet do not have ears. Pont the tweeters up to you or mount them higher on the dash.
      3) Subwoofers - doof doof
      Speakers are not connected to RCA pre-out leads!!!
      Speakers connect either from the Speaker outputs on the back of the HU (using the HU built in amplifier), or you connect your speakers to an external Amplifier. All speakers have 2 wires ... except those OEM speakers that do common negative grounding and are a PITA.
      You can have as many speakers you want in a car... but you are still only going to use Front L+R and Rear L+R (and Sub L+R) - unless you are into multimedia/DVD's and have 5.1 HU then you will also have a centre speaker.
      How many speakers you run is up to you and the space needed to install them.
      You then need to consider how to wire them up. HU will want to see only 4ohms per channel from the built in amplifier.
      so you wire the speakers up into 4ohm configurations. (Most Car audio speakers are 4ohm).
      If you use and external amplifier to drive multi speaker set ups, then you can run speakers at what ever ohms the amplifier can handle - just make sure you wire the speakers up acordingly... subwoofers can run 4, 2 or 1 ohm if your amp can handle it.
      I have 11 speakers in my Mk3 Golf Split Fronts (Woofer and Tweeters), Split rears (Woofer, Mid and Tweeter) and Dual Voice coil Sub - does that count as 12 speakers then???
      I fixed up some of your misconceptions.
      \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
      ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
      • #18
        Mate, there is no need to burn up my post. Sounds a bit silly anyway, because you basically just gave a confusing version of what i said:
        I mentioned RCA Pre-outs, and you said they went to amplifiers. What about these "RCA PRE-OUTS"?
        I also mentioned the different types of speakers. What I was referring to was the types of speaker-cone-thing-whatevers, not style of speakers. Sorry I didn't make that more clear..
        SORRY. I said Pre-outs instead of speaker outs. It was wrong. However I didn't say RCA so my "SIMPLE" explanation still sounded alright..
        That's just starting to take stabs. I posted this for someone who wouldn't have stupid amounts of speakers. Think realistically..How many speakers will you really cram into one speaker output? We're talking no amplifiers here.
        And here comes the derogatory comment.
        You actually said more confusing things (NOTE: I said simple explanation, ie dumbing down and generalising), correcting my one mistake of RCA pre-outs.
        • #19
          Dude... You do not know what RCA Pre-outs are!
          It's information like this that confuse the newbies and they go blow up their speakers!
          • #20
            Then say that Don't try to correct everything I said cause it didn't all need to be corrected. All cooooooollll okay?
            • #21
              Lol that was an amusing thread, I wonder why no one was warned there. Keep the slagging for another site, I learnt that the hard way...
              Change of subject...
              What is the best value for money audio enhancement product for a car? Head deck? Amp? Someone tell me since I'm such a tightarse
              • #22
                Hmmm...best value for money? Surely it's gotta be speakers..you can get better sound quality obviously for price of the speakers.
                If you bought amp, you'd need cables, more labour time, and probably better speakers unless u just wanted to run your stocks off the amp.
                you've got an alpine headunit, and unless you want to give that to me i wouldn't be changing if i were you
                • #23
                  [QUOTE}
                  you've got an alpine headunit, and unless you want to give that to me i wouldn't be changing if i were you[/QUOTE]
                  Hmnn good point, it is a rather good stereo anyway, I didn't realise until I had driven the car for a while. Hmnn I'll have to think about it some more...
                  • #24
                    Originally posted by Golf Houso View Post
                    [QUOTE}Hmnn I'll have to think about it some more...
                    I hope by that you don't mean think more about your headunit..I'm going to stick to the assumption that you're thinking more of speakers! When personal funds become available () i shall be purchasing a lovely set of Kicker speakers from ebay. They'll work out to be 100 bucks per pair (two pairs), plus postage of maybe 80 bucks for the four speakers? that's cheaper than $220 a pair from JB HI-FI which is the only place i've seen them.
                    Mind you, this isn't very cheap..i'm looking for very good quality speakers because i'm amping them - if you're looking at amps, i might need to upgrade mine if you're at all interested..but if not, walk right into your nearest strathfield and see what they have to offer - speakers make a noticeable difference for, let's say, a good price!
                    • #25
                      the &quot;Im tighter than the arse on a fish&quot; system under $100
                      My Mega Low Budget Tightwad System does me just fine
                      My total cost so far is $90 give or take $2 for adhesive foam
                      Sony 4x45w CD Headunit ( $35 from cashies ) CDX something blah blah
                      Front 6"'s in doors were already there ( FREE - woot,woot! )
                      Front Tweeters in dash - with inbuilt crossovers - ( $10 Jaycar discount table )
                      Used Rear Panasonic 6x9's ( $20 mt gravatt markets )
                      Massive Fujitsu10 4 Channel Amp ( $25 rocklea markets )
                      12 Inch Blaupunkt 400w rms Subs ( FREE from a mate if i repaired one of the 12's) loaded into a dual 12 carpeted slimline angled cabinet
                      I got the particular Sony head unit because when you use the RCA SUB out from the onboard crossover, it applies a low frequency cut off for the onboard amp channels ( Front splits and Rear 6x9's are run on headunit cut off at 80htz )(if youre not sure - that means the lower bass frequencies are cut off at that pre determined frequency ie 80htz here)
                      This also means the head unit sucks less power when its turned up quite loud
                      ( ever seen the lights on your headunit dimm to the bass ?)
                      The Fujitsu 10 amp is a 4 channel unit and is running in dual bridge mono mode IE using it as a 2 channel amp to provide a bridged channel for each of the Blaupunkt 400w rms subs in the boot - Always make sure your amp has a good fused positive source from the engine bay and a secure local earth ( No the screws holding it down arent enough )
                      The sub is pretty heavy so I just stapled some velcro on the bottom of it and it grips damn firmly to the boot carpet ( it lifts out the whole boot floor when you take the sub out)
                      If you put your head back in the seat it shakes your eyeballs with a bass kick and thats loud enough for me
                      Wiring
                      Head unit - used existing power
                      front speaker - existing speaker wire
                      tweeters - came with free wire - woot
                      6x9's - 1 run of old 4 core power cable
                      Sub Amp - Positive line from engine bay I used an old 10 amp power lead and twisted all 3 cores together
                      Subs - Old 15amp power cord from amp to cabinet -
                      Brand names are great if your into that stuff but nobody can even see the damn logos on my subs in the boot or the name badge on my hidden amp and if you want to pay out the arse go right ahead.
                      Keep in mind what sound you want and above all dont just slap in any old crap look at the specs to see what the stuff is capable of - no name gear sometimes out performs the brands by far . . . .and some
                      Always happy to give free help to any dubbers in brisbane PM me
                      • #26
                        Got some doof today! Be pumping tunes soon.
                        Ol mate big Steve knows what I got Its fully sick bcuz it Pioneer
                        • #27
                          totally agree Mrk Mickey, speakers give a good improvement on sound vs. buck
                          dont listen to some of the other guys, im sure everyone here appreciates your input, the more conversation around this subforum the better, things have been a little boring/quiet around here as of late...
                          i consider myself to have a sound knowledge on car audio/installs (i have been mucking around with stuff for years, done short TAFE courses, built custom fibreglass boot installs etc etc) yet i still dumb things down when i do post to help others undersand in laymans terms...
                          although i have found that it does depend on what sort of speakers you are actually starting off with. for example, the standard speakers in my MK4 were reasonably good when i changed to an aftermarket HU as i was able to drive them with more power and less distortion
                          this was only a temp solution while i got some otehr stuff installed, however you get the idea...
                          hypothetically if i had changed to aftermarket speakers with the stocky HU i dont think i would have reached as much of a improvement as the standard unit are absolutley ****ehouse... nameley due to the fact that it lacks any form of decent HP/LP crossover (most HU's have this these days, even the cheapies)
                          not sure what the OEM gear in the MK3's are, however as always, i recommend a decent HU, some reasonable speakers and if you can stretch it, a small 2 channel amp to run them
                          i bought a pioneer unit today (for my brothers workhorse) with MP3, ipod control detach face, remote and 2 sets of RCA's brand new from JB HiFi all for a tiny 120 bucks. add a set of speakers for around 200 or so and mabe a small second hand amp off a forum etc and you can have a reasonable system for well under $500. might also add that something like this may be upgraded later down the track with a sub or rear fill speakers easily. again i have seen 'cheap and cheerful' sub and amp combos from autobarn etc for under $200
                          may seem alot to some, but these days a bloody ipod can cost more...
                          just some thoughts... keyboard warriors take your marks! haha
                          1999 MK4 GTi 1.8T - Custom Code Stg 1, ECS Stg 1, 14lb Fly, 18" A8's
                          ''Jap cars pull the G-Forces... Euro cars pull the G-Strings...''
                          • #28
                            Shameless plug, but check out www.mobileelectronics.com.au
                            Huge community dedicated to wonderful car audio
                            If your budget is only $500, then i'd look at spending ~$200 on the headunit, and $300 on a decent pair of 2-way 6" splits.
                            Headunit of your choice - whatever looks pretty and has the features you want.
                            The 6" splits will sound better then any 4" will. They'll player lower, and give you a more full sound. I would recommend something along the lines of Hertz HSK165's, JL Audio VR600-CSi's, Crescendo Opus 8.6's, Boston SL60's etc...
                            Cabling should cost very little (speaker wire from headunit to speakers), and installation shouldnt be difficult so you could attempt it yourself.
                            Run the splits off the headunit, and run the stock rears for the meantime (i'd recommend against rears altogether, if you want justification, let me know and when I have time to write an essay i'll tell you ).
                            If you find the sound isn't enough for you, look at purchasing an amplifier down the track.
                            A small 2ch amp to power your front splits (~2 x 75wrms) would suit fine, and run the rears off the headunit.
                            Then buy another amp (monoblock) and a subwoofer... and let the addiction bite
                            • #29
                              Man who knows how the **** you operate the head unit... I know how to put in a CD and turn up the Volume loud.
                              BTW I got my Head unit all wired up today
                              • #30
                                I'll have to take a photo of my headunit + processor + spaceship remote for you then
