i've just retrofitted a RNS510 F unit into MY12 tiguan. its rather surprising everything seems to be plug and play with out VCDS coding!? steering wheel controls worked, factory bluetooth worked, full MFD integration with compass etc...but after an VCDS scan, error codes turn up for the microphone module under satnav. my guess its the voice control mic thats not plugged in. upon research some said you need the wiring harness for the original factory bluetooth mic to work with RNS510? Some said all you need to do is switch the + and - mic wiring pins of the factory bluetooth mic to the back of the RNS510 unit? which is true? i cant seem to find any diy info on the mic wiring pin swap.
My car has the factory Optical Reverse Sensor installed is it possible to have the distance displayed on the RNS? how do i code it with VCDS if its the case?
any help is appreciated
