Hi all,
Recently installed a dynaudio amp 3C8035456C from a Passat CC into my R36. Amp was a simple plug and play and the difference in sound quality is quite decent.
My question however is that now when I do a VCDS scan it comes up with the below error. I assume this is because of an incompatibility with the CC amp.
Only VCDS change I have done is enabling dynaudio. All this has done is bring up the logo on startup.
Any suggestions on getting rid of the error code as apart from this it works well.
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No SW: 3C8 035 456 C HW: 3C8 035 456 C
Component: DSP 10 Kanal 0070
Revision: 00H05001 Serial number: 75805000534103
Shop #: WSC 00000 000 00000
VCID: 2855E3919B3BBC58495
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Mileage: 27925 km
Time Indication: 0
Date: 2031.14.03
Time: 17:41:06
Freeze Frame:
Raw, Form. N/A: 000 000 000
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Mileage: 27925 km
Time Indication: 0
Date: 2031.14.03
Time: 17:41:06
Freeze Frame:
