My radio and navigation screen will not operate. I think it could be a fuse but cannot find it. I do not have a plan for fuses in the car which is a passatcc 2009/MY2010. Can anyone advise me as to the problem and the way to fix it. Thank You.
Radio/Navigation Screen Blank
So far as I know, the internal fuse box is in the same place as the Golf — at the end of the dash panel inside the driver's door.Originally posted by SIDEVALVE View PostMy radio and navigation screen will not operate. I think it could be a fuse but cannot find it. I do not have a plan for fuses in the car which is a passatcc 2009/MY2010. Can anyone advise me as to the problem and the way to fix it. Thank You.
The trim panel pulls off quite easily.
The manual is no help for fuse layout, as it varies from car to car depending on what's installed.
However, finding and replacing blown fuses is a simple matter — just look for the missing wire in the fuse body.
There should be a removal tool clipped to the trim panel.
Radio/Nav Screen not working
Thanks Idle, I know of and opened the fuse panel at drivers side of car. You are correct as I can't find a fuse layout in the manual. I was a bit worried about pulling out each fuse to check for breakage as this car has heaps of them and I worry about causing any other problems. Volkswagen dealer told me the fuse for the screen was behind the actual screen. So thought I would just check with you as to remove the screen is beyond me. Do you think this is correct. Thank You.
From memory, there is indeed a fuse in the back of the head unitOriginally posted by SIDEVALVE View PostThanks Idle, I know of and opened the fuse panel at drivers side of car. You are correct as I can't find a fuse layout in the manual. I was a bit worried about pulling out each fuse to check for breakage as this car has heaps of them and I worry about causing any other problems. Volkswagen dealer told me the fuse for the screen was behind the actual screen. So thought I would just check with you as to remove the screen is beyond me. Do you think this is correct. Thank You.
Is there any warranty left on the car? Did you just call to the dealer or went there? To check the fuse at the back of the unit you have to remove the unit.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Does the radio still work? Just wondering if maybe you inadvertently turned the display off. Probably already tried that, but you only mentioned the screen being blank.Originally posted by SIDEVALVE View PostMy radio and navigation screen will not operate. I think it could be a fuse but cannot find it. I do not have a plan for fuses in the car which is a passatcc 2009/MY2010. Can anyone advise me as to the problem and the way to fix it. Thank You.
Graphite Blue TDI| DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs| Full LED interior|US GLI paddle shift MFSW|Carbon Vinyl wrapped trims|Colour Coded Votex Body Kit|
Radio screen blank
Thanks for the replies( DragonzBreath, Transporter, Buckets.) There is no warranty on the vehicle now. The radio does not work and I can't turn on the screen. Dealer has told me there is a fuse at the rear of the unit. It is going in to the dealer tomorrow(tues 18th.) to be repaired. I was too worried about trying to pull out the unit myself, so, will have the experts do it. Just hope the cost is not too great!!!!!!!!! Thanks again for your replies.
Have a look at the My-gti.com website, it isn't that hard to remove the radio yourself, and I find it odd that the/radio fuse has blown and the other hasn't. Also might be worth looking in the vcds who can help thread if there is someone local.
Vw will charge you the time it takes to remove and reinstall the radio - expect about 1 hour (I can do it in less) and if it isn't that fuse, well, they'll charge you anyway...
Sent from my Nexus 7 using Tapatalk 22013 MY13.5 Passat V6 Highline Wagon. Watch this space
GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
Sorry I didn't post earlier — got involved elsewhere.Originally posted by SIDEVALVE View PostThanks for the replies( DragonzBreath, Transporter, Buckets.) There is no warranty on the vehicle now. The radio does not work and I can't turn on the screen. Dealer has told me there is a fuse at the rear of the unit. It is going in to the dealer tomorrow(tues 18th.) to be repaired. I was too worried about trying to pull out the unit myself, so, will have the experts do it. Just hope the cost is not too great!!!!!!!!! Thanks again for your replies.
Removing the radio is very simple — the surround trim is quite easily pried out, uncovering the retaining screws.
Remove those (Torx 20, usually) and the unit just pulls out. The cables are normally quite long, so you won't strain anything.
Are the a us models the same?
Radio Screen now Fixed.
Took car into VW dealer this morning. It appears there were some wires disconnected which were relative to the bluetooth system. Repaired and all works fine. took 1 and a bit hrs. at a cost of $129.00. Thanks to everyone for your advice and help. Regards.
