Hi Guys,
The all new Zenec model is only a few weeks away from launch (expected middle/end July)
Those already familiar with the NC-2010 (outgoing model) will know what to expect, and by all reports, this new model makes the 2010 look vintage.
Pricing is set to stay the same @ $1995, with free delivery Australia wide.
4WD Accessories - Wolf 4x4 - Zenec NC-2011D for VW / Skoda
E>GO ZE-NC2011D – custom-fit to your VW
The ZE-NC2011D is a smart specialist, specifically developed for your VW. The specific construction, white/red button illumination and custom ized styling of the front panel makes ZENEC’s top naviceiver blend in perfectly with the VW models Golf VI, Golf V, Tiguan, Eos, Scirocco, Polo V, Passat, Passat CC, Jetta, Caddy, Touran, Touran II, Sharan II, Amarok, and T5 Multivan.
The ZE-NC2011D is also effortlessly integrated into the existing auto motive electronics. The E>GO is linked to the steering wheel remote control, the Multifunction Display (MFD+), Optical Park System (OPS), and the Climatronic control status via the vehicle-specific CAN bus interface. The full functionality of factory in-stalled components remains intact.
The ZE-NC2011D is suited for installation into the radio slot of the above named automobiles without further modifications or additional adapters: simply take out the factory radio, put in the E>GO and drive off...
Phase Diversity FM Dual Tuner
The dual tuner of the E>GO is working with an FM phase diversity circuit that processes the signals of the two antennas built into the vehicle. A DSP algorithm generates the desired noise and distortion free FM signal by merging both captured radio signals into a new audio stream – you always enjoy optimum radio reception, even under difficult conditions.
Optical bonding
Optical Bonding improves display clarity and contrast under direct sunlight conditions. The anti-glare coating on the touchscreen and the internal lamination of the touchscreen to the TFT LCD display prevent internal reflections and light refractions – for a visible improvement of contrast and sharpness.
Steering wheel remote control integration
The ZE-NC2011D is connected via the vehiclespecific CAN bus interface to the factory installed steering wheel remote control. A/V sources (radio, CD/DVD, MP3, USB) are operated in identical fashion as with the OE radio before.
E>GO is a perfect fit: The ZE-NC2011D also supports the Multifunction Display (MFD+), that is connected to the CAN bus. Displayed are turn key arrows, as well as radio station and track infos from all audio sources.
A/C control status info integration
The status data of the climatronic, if installed in the respective vehicle and present in the CAN net, are displayed as a Pop-Up info on your E>GO’s touchscreen display during adjustment of any A/C related function.
Parking sensors
Perfect integration into each target vehicle – data present in the CAN net for factory installed parking radar sensors is read, processed and displayed via the ZENEC OPS (Optical Parking System) on the Touchscreen of the E>GO.
GENERAL FEATURES
Intuitive, user friendly HMI in 20 different languages
6.5"/16.5 cm 16:9 HD TFT-LCD display with 800 x 480 pixels resolution and touchscreen control
RDS tuner with 30 preset stations (18 FM/12 AM)
Multi zone function
4 x 50 watts class-D amplifier
2 x IR-remote control
BRAND/VEHICLE SPECIFIC FEATURES
Steering wheel remote control integration via CAN
Multifunctiondisplay Plus (MFD+) integration via CAN*
Optical parking System (OPS) integration via CAN*
DYNAUDIO soundsystem integration
Red or white key illumination selectable
* Functionality only provided if feature specific CAN Data present.
GPS NAVIGATION SYSTEM
3D High-Definition navigation system
TMC and TMC Pro receiver
External GPS antenna
8 GB internal flash memory with map data for Australia and New Zealand and Premium POI database
Graphical user interface and voice guidance in 28 different languages
2D or 3D map view with auto-zoom and display of 3D terrains and 3D landmarks
Eco and Smart Route Planning, Outlook address import, Real Junction View and Real Signpost rendering etc.
Text to Speech function
PARROT BLUETOOTH HANDS-FREE MODULE
Synchronization of up to 1,000 contacts with max. 5 telephone numbers per contact
Alphabetical search function for contacts
Internal and external microphone
Future-proof upgradable Bluetooth firmware
MULTIMEDIA PLAYER
DVD loader
USB 2.0 port (via Media link box)
SD/SDHC card reader (up to 32 GB)
Made for iPod/Made for iPhone
Playback DVD loader: CD, CD-R/RW, MP3, WMA, DVD, DVD±R/RW, DVD-MP3, AVI, Xvid and JPEG
Playback SD/USB: MP3, WMA, AVI, Xvid, H.264 and JPEG
A/V-CONNECTIONS
4.1-CH preamp line outputs
2-CH preamp line outputs without volume adjustment
2 x composite video outputs (NTSC)
1 x A/V-input
1 x video input for rear view camera with switching function
Connectivity for compatible external DVB-T or DAB+ receivers
Optical bonding
Parking sensors
GENERAL FEATURES
Multi zone function
MULTIMEDIA PLAYER
DVD loader
A/V-CONNECTIONS
1 x A/V-input
