ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  • But then... won't it look bad in an horizontal position?
    • Originally posted by wanxu View Post
      Turn the protector around Not the screen. When they polarize things they work one way and not the other.
      Take your sunnies off and turn them up and down in front of the screen and see if it comes clear Our ticket machines had polarised glass in them and one had been put in crossways instead of up and down or vice versa.
      When I looked at it normally I couldn't see through it If I turned my sunnies 90deg I could.
      Didn't use that bus any more as was a pain
      • Update on the MCU issue - my mistake, you CAN actually downgrade the MCU, just can't flash the SAME version of MCU that you already have. This means those with the OPS being stuck issue can solve it simply by downgrading your MCU with the last update, until the issue is solved with the next update.
        TR 08 Golf GT TDI, Custom Code Phase 1, Milltek Exhaust, Whiteline RSB + ALK, APR Carbonio Intake
        • DkN, any updates on the new version of the HU? thanks in advance!
          • Originally posted by DkN View Post
            When is the next firmware due out? I am so sick of looking at the reversing screen even though i have no backup camera or sensors AND it shuts the audio off.
            • Originally posted by DSGVW View Post
              I'm not sure but I just said you can flash the previous MCU to stop this behaviour, in the post you quoted.
                Gosh if that pisses you off you must spend a lot of time in reverse!
                • i wonder if the factory parking lines will turn with an after market rear view camera
                  • Originally posted by chocolatemoose View Post
                    Yes they do. Not sure about use of the word 'factory'. The ANS head unit generates lines off the canbus info.
                    Tiguan MY12 118TSI, white, no frills..... Had ANS810 ... Note the HAD ..... Now got RCD510 supplemented by 7" Android TomTom mounted on a HoldMyPhone .... Upgraded speakers Vibe BlackAir front splits and MBQuartz 12" ported sub driven from Infinity Reference 5350a amp .... oh and added fun
                    • Will their be an upgraded/new version available for the Touareg?
                      Mk6 Golf GTI | Carbon Steel Grey | Single Clutch Human Controlled 6 speed transmission | 5DR
                      • Originally posted by whiskywallah View Post
                        Yup, I've always wondered about VW's decision to build an entire module that costs hundreds of dollars when the steering sensor info was available to be read from the CAN-Bus all along.
                        The new platform will be rolled out across all models, but beginning with the more mainstream Golf / Passat etc model.
                        • I have a 2004 Audi S4 with the RNS-E and Bose stereo, will one of your 8” Screen units fit this car. I am not sure if the CANBUS is compatible as i know the new RNS-510 and MMI units are incompatible.
                          I am looking to ditch the RNS-E but i don’t want to go for a screen smaller than 8” and also want to keep the OEM look so the usual double din head units won’t work either.
                          • Originally posted by dtpearson View Post
                            Unfortunately you will need a unit designed for the Audi CAN-Bus, and while my supplier does have one for the S4, it's 6.5 inch just like OEM:
                            Car dvd /Car gps/VW GPS/BMW GPS Professional manufacturer-Audiosources Electronic Technology (Shenzhen) Limited
                            • Re: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
                              Hi,
                              I have a 2013 Jetta with bluetooth and OPS. I understand that the OPS will be displayed on the ANS 810 (might need a firmware downgrade) but how would the original bluetooth (not the one from ANS 810) interface with the unit? Is it possible to use the original mic for the bluetooth?
                              Sent from my GT-N7000 using Tapatalk 2
                              • Originally posted by t0n13 View Post
                                Hi,
                                The unit comes with built in Bluetooth so you will not be able to use your OEM one. The current generation units also do not have an external Mic option, but I believe the new units will - have to confirm on that.
