Rns510 & rvc help please
  • Rns510 & rvc help please
    I fitted an RNS510 C to my MY12 Golf R. I ticked the relevant box in CAN gateway list and all is good as far as nav and steering wheel buttons.
    The optical park assist also works fine but he camera doesn't. Can anyone help with tis please?
    Mine didn't work when I installed it either. I used the Kufatec kit. When I put the car in reverse, the OPC worked but the screen was just all coloured lines and the badge did not open up at the back. After checking the coding and wiring a million times I gave up and unplugged it.
    2017 VW Tiguan 140TDI Highline
    2012 VW Touareg V6 TDI
    1985 Mercedes-Benz 380SE
      you have to code the RNS to say it has RVC
        From memory: Have you tried a couple of check boxes around the bottom of 39 NAVIGATION in the VAG COM screens? They are labelled as something having to do with reverse camera. I used to have your opposite problem (no RVC) and that fixed it. Sorry cant be more precise as I don't have it in front of me
        Golf GTI ED 35: DSG, Candy White, Tinting, RNS510 retrofit
          Thanks,all good now
            So do you have the parking guidance lines appearing on the screen too? Does the optical park assist appear on the same screen as the reverse camera? I retrofitted a camera but it doesn't have the lines and when activated shows the box on the left where the optical park assist should be, but there's nothing.
            MY10 Silver R36 Wagon
            VW Classifieds Username - VWC-adrock
              I am having the same colored lines problem. I have coded it for back up cam low. Is there something else that's needed?
                Yes I do have the lines and the icon of the car is on the screen although you can opt to not have it. Sorry I can't offer anything to help you
                Not sure exactly how I did it now, a fair bit of trial and error with the coding
