Ground in MkIV Bora boot ?
  • Ground in MkIV Bora boot ?
    Hey Guys,
    I need a ground in the boot. I have mounted the amps on some MDF in the tyrewell and I have 0 gauge coming from the battery going into a nice Distro block. I need a 0 gauge ground can anyone recommend where to find one or if not, where is the best place to drill without making to much of a mess ?
    Thanks !
    Audi B4 80 Q V6'94 Race Car !! KEGGED
    Audi B4 80 V6 Avant'94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT'06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo'01 Gone
    You can pretty much ground the Amp to any part of the car's bodywork. If you have a decent ground circuit in the car, then the bodywork will be earthed.
    So, look for a bolt that's fitted into the bodywork - usually something like a seatbelt harness or light fitting etc. Then unscrew it, scratch away the paint to ensure a clean contact with bare metal, and earth the amp. Best to use a crimped connector on the earth wire for a solid connection.
    Hope this helps...
    Jon.....
    Originally posted by qsilverza View Post
    Hey Guys,
    Thanks !
    //:MK3 Golf/2.0/15's/Stock Height/Smoked Repeaters/Mk4Badge/Alpine Head Unit
      seat belt mounts tend to be in very strong areas, and make very good grounds. They are my favourate points.
