Hi all,
I am thinking of purchasing a R32, and have been doing some research into the Sat Nav options before i choose to buy a car.
Initially I was just looking for cars with factory fitted Sat nav - which I presume is the RNS 510 model. Naturally this filters out a good many R32's. However my understanding is that the factory fitted version does not have speed/saftey cam info on them with audible alerts, (Having read many threads this still doesn't seem to be an option?), and the map interface isn't all that great either.
So then i started looking at alternatives and read yet more threads on the various options:
Zenec NC2010
Dig Option
Kenwood DNX520 (though not sure that works in Aus?)
Pioneer F9310BT
So it seems as though maybe I should just try to get an R32 without the factory Sat Nav (which should be a little cheaper), and then fit one of the aftermarket options.
I really like the idea of having the navigation turn information repeating in the MFD, and it seems as though the Zenec option will do this (with some coding). However i just wanted to make sure that there wasn't more than one version of MFD, and therefore compatibility issues?
The reason I ask is a i saw a 2007 car (without factory fitted sat nav) and the MFD displayed the gear selection in a column on the right, however in a 2008 car (with factory fitted satnav) the gear selection was at the bottom.
Is it just a gui thing because one had satnav and the other didn't, or are there different versions of MFD screen that i need to consider?
I presume if i want the navigation to appear in the MFD then Zenec is my only option?
thanks
Simon
Zenec NC2010
Dig Option
Pioneer F9310BT
thanks
Simon
