Hi all
Anyone experience this - the firmware upgrade worked fine, as I thought, and everything appears there. Also upgraded to V5 maps. Screen is more sensitive, it's certainly quicker to respond and loads/starts up quicker.
But, on the night setting, the screen is flickering between various degrees of brightness. Not much, but enough that if you watch you can see it getting slightly lighter or slightly darker as if its not sure what the brightness should be.
Anyone experienced this? It was a C unit, (1T0035680C) and is now 1T0035680D, running 3810 (upogarded from 2680) and maps 7679
Have rebooted a few times and going to see how it pans out, but it does seem as if in daylight mode it does NOT do this - only when varying degrees of brightness are available.
