RNS Firmware upgrade to 3xxx
  • RNS Firmware upgrade to 3xxx
    well...I bit the bullet and tried to apply FW3xxx (karmolds custom FW) this morning and each time I attempted it, it returned an Error 10306
    Currently running the following: Del. Part. No. 1 T0035680 C
    HW-Version H05
    SW-Version 2760
    SV SW-Version C_EU_9.242_t520
    Running map 7492 (V4.1)
    Any thoughts? Might go and pick up some new media and try that, however the current media (DVD-R) that I have used has worked successfully previously. Is anyone able to confirm that the unit quoted above is definitely a C unit and not a re-badged/flashed A/B unit? 'cos if it's a the latter, then FW2760 would appear to be as far as I can go, without going to the trouble of getting a new motherboard etc. And I'm not about to do that.
    ---------- Post added at 03:32 PM ---------- Previous post was at 12:24 PM ----------
    investigating further.....here is the version.txt file from the 3xxx FW disc:
    Software Loading CD for CP2 based units
    (c) CONTINENTAL Wetzlar
    CdTreeBuilder version 3.06 is used.
    #CD 0 0 5 . 2 3 4 . 3 0 1
    #DATE:2011-02-26
    #Project: VWRNS
    #Author: RoNe
    #Steckbrief: C_EU_10.344_t190 C10/C6
    #CommentStart:
    This is a SWL CD for VW delivery.
    #CommentEnd:
    #Integrationphase: Delivery cw22/11 C10/C6-samples
    #VwSwPartNumber:1T0035680D/1T0035680D/3T0035680B/7F0035680A/7E0035680A/1T0035680F/1T0035680G/3T0035680C/3T0035680D
    #VwSwIndex:3970/3976/3978/3974/3970/3970
    #AppsBuild:C_EU_10.344_t190 C10/C6
    #CRC16:8db4
    I note that my unit 1 T0035680 C is not listed in the Part number file. Guess this means it's not suitable to a C unit........
    Thoughts?
    ---------- Post added at 03:42 PM ---------- Previous post was at 03:32 PM ----------
    So...6 x DVDs & 1 x CD later.....no joy.
    I reckon it's because the Part Number of my unit doesn't match the required info in the disc TOC file.
    Bummer
    I definitely have a C unit and it definitely all works on mine.
    Only way to tell for sure what your unit is, is via a VCDS scan.
    Suggest you try installing an original unmodified FW 3970.
    If that works, then it's got nothing to do with your unit.
    MY11 Tiguan 147TSI (SOLD)
      I remembered I had a VCDS scan log tucked away on my HDD.....found it. Was done when i had the issue with the steering wheel controls with FW2660. Of course, that's been resolved now.
      Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
      Part No SW: 1T0 035 680 C HW: 1T0 035 680 A
      Component: RNS-MID H05 2660
      So...that's definitely a C version unit, true?
      And...I'll give a FW3970 (unmodified) a run for it's money and see how I go.
        Sorry to disappoint ... but your unit is an A.
        Basically the VCDS scan doesn't lie:
        But your unit does, when you view it via secret menu.
        Your FW 2760 installed makes it look like a C unit.
        Just like mine appears to be a D unit after installing FW 3970.
          ah bugger...oh well. Half expected that FW2760 was gonna be as far as she would go.
          All good.
          Many thanks for confirming the inevitable.
            have you tried the file for the A/B/C units as mentioned in Mav's page? Volkswagen RNS 510 Firmware Upgrade to version 3810 / 3814 / 3816 / 3818 | my-gti.com
            I upgraded mine and wifey's and mother's C units to 3720 this weekend. It took a while.
            Main Dub:
            2010 Crafter Hanover Bus
            1956 Type 1
            2015 vRS wagon black on black
              Happy to give it a go. Why did it take a while? Do you mean the time take:
              1. To download, or
              2. To apply the FW update to the 3 units?
              3. Or the fact that applying it to one unit took a while.
              Make like Pauline Hanson.
              "Please explain"
                Cause he was upgrading 3 units.
                But the suggestion to upgrade to FW3810 should work.
                  worked.
                  I must've grabbed the wrong file last time.
                  I now have an A unit that thinks it's a D unit. Running FW3810. V4.1 maps (unmodified) with ALL OEM POI's working. MFSW works as well.
                  Happy Days!!
                    good to hear. Yes I did 3 cars at once, and had to reload maps and music, it took msot of my saturday afternoon!
                    Main Dub:
                    1956 Type 1
                      hehe, I still haven't reloaded all my music yet. I forget where I'm up to (can only fit so much onto my 8GB SDHC card)
                      Audi A3
                        I finally decided to jump onto the bandwagon..updated to unmodified 3810 from 2720.
                        But this is odd, my v4.1 maps were still intact without needing to re-install it. All my settings were still there. Very strange!
                        Before the update, I installed v4.1 maps over my v3 on my fw2720 Hw41 ver C. After enabling the secret menu through VCDS, my HDD shows 3 partition on a 2720 which I thought was odd.
                        I got my RNS replaced after a theft case involving my RNS being ripped out (long story!)...I had the new boot screen at first, but after enabling my Dynaudio, the splash screen went back to the old pic with the Dyn logo.
                        I'm thinking that my RNS is actually formatted with 3 partitions but running 2720. Any ideas?
                        I stlll hv a problem where it started after updating to V4.1 maps; my location is always a few metres behind the actual even at static mode (stopped)..some forum readings tells me about some compass signal issue but think it was only for US ver?
                        Today I went for a drive to get a fix on the Gps satelites, i noticed after getting a full fix (~6/8 sats) and making a turn, the car turns into the road on the screen but the map doesn't turn together. The map rotates (points forward) after a few sec. Any suggestions? It was working fine with V3 maps and 2720.
                        Current: | MY09 R36 | Dynaudio | RNS510 SatNav |
                          I've got a version C with firmware 38xx and 4.1 maps and have a little lag - guess that's why the newer versions of the RNS have faster processors now.
                          Audi A3
                            From memory 3810 doesn't actually re-format the HDD.
                            So that explains why you don't lose anything.
                            The lag is normal for C units since we're all punching above our weight on 3XXX series FW.
                              ah....FW3810 does format the HDD. I installed it last weekend...lost music and maps
