**LOOK HERE FIRST** Important Threads & Stickie Index.
This is a sticky topic.
Performance Tunes from $850Wrecking RS OCTAVIA 2 LinkTags: None
- Stuck
Commonly requested files (please don't ask usage questions here, find the correct thread to post in):
List of members able and willing to help you with various retrofit installations and/or VCDS coding.
RNS510 Video in Motion (VIM) - Not required if upgrading firmware using links below
* Install VIM (Berto CD)
* Uninstall VIM (Berto CD)
* Alternate VIM installation CD
(More info...)
RNS510 Firmware
* Firmware 272x for recovery purposes
* Firmware 3810 (recommended for A units)
* Firmware 3970 for 1T0 035 680, 1T0 035 680A, 3T0 035 680, 1T0 035 680B (includes VIM, secret menu, and custom 90:5:5 HDD partition ratios)
* Firmware 4020 for old version A units only (note that installing firmware version 3xxx will make older units appear as a D version, this D should be ignored).
* Firmware 4020 for 1T0 035 680C, D, F, G and 3T0 035 680A, B, C, D units (includes VIM, secret menu, and maintains existing HDD partition ratios (default or custom)))
* Firmware 4120 for RNS510 (burn to DVD+R, includes VIM & secret menu, uses default European partition sizes). *Requires VCDS to backup and restore RNS510 coding*
* Firmware 4120 for RNS510 - 90:5:5 partitions, VCDS shouldn't be needed (still being tested).
* Firmware for European units
(More info...)
RNS510 Australian Maps
* Erase Maps Partition (for reloading the same version of map data - music partition should remain intact)
* Version 4.1 Australian Maps with extra custom POI built-in
* Version 5.0 Australian Maps with extra custom POI built-in
* Version 6.0 Australian Maps
RNS510 Points of Interest (requires Firmware 38xx+ and Australian Maps 4.1+)
* PersonalPOI.db3 file for loading via SD card (saved in \root\PersonalPOI\)
* POI.db3 file for injection on Maps 4.1 disc
* POI.db3 file for injection on Maps 5.0 disc
(More info...)
Bluetooth Information
* Summary of Bluetooth Units as of 2009, skip to later pages for more up to date info
Summary of the summary thread:
* The dealer-advertised dash-mounted unit is generally held to be rubbish for the price, so avoid.
* Then there's the range of premium VW/Skoda units that integrate with the head unit and MFD (depending on car, may not apply to some trend-line vehicles):
<> 9W2 features A2DP music streaming but no phone book download
<> 9W3 features address book download but no music streaming
<> 9W7 features both of these with more features/settings. Check part numbers to make sure you're getting the latest version available so you don't miss out on any features (such as track skipping via the car controls).
<> 9WZ is similar to 9W7 but also feature Remote SIM (RSAP) mode. Calls are made via a car antenna instead of the phone, and SMS messages can be sent from the RNS510 keypad. This mode disables 3G Internet on your phone however, and not all phones support RSAP.
Click here for more information on RSAP compatibility.
Units can be purchased from eBay or CarSystems.pl (products from CS usually arrive in Melbourne within 4 business days).
For more up-to-date info and questions check this thread
This post is a WIP (will tidy up and add references over next few days as time permits). If you have suggestions feel free to PM me.
To burn the contents of an ISO file to CD in Windows 7, right-click the file, select Open With > Windows Disc Image Burner. Otherwise use Nero or Roxio or Toast or whatever you use.
Warning: Please do not make use of any files linked above without reading through the threads containing them and understanding the implications (if any). Please don't everyone PM me for help either, ask in the forums so that everyone benefits. I only compiled existing info and links contributed by others so don't deprive yourself of their expertise.
Can Gateway software upgrades (reprogramming) availabe in Adelaide. No need to buy gateway from the ebay, save time money and hustles with the installation, I can upgrade it without removing/disconnecting it from the car.
More details in this post. http://www.vwwatercooled.org.au/foru...tml#post846268
****DO NOT ASK ANY QUESTIONS IN THIS THREAD, LEAVE IT FOR THE IMPORTANT STUFF, YOU CAN ASK ME IN THE THREAD ABOVE!****Last edited by Transporter; 12-10-2012, 06:59 AM.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
