Originally posted by kamold
View Post
Collection of POI's
This is a sticky topic.
Ha... I was almost stationary from Fairford Road until the M5 Tunnel so even contemplating 120 was laughable...Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint
Cup Rear Spoiler, VMR V718 GM rims, APR Tuned, Brembo 6 pot BBK, Eibach Pro-Kit springs, Low line RVC, Exhaust flap delete
Hey Guys I am after some help. I have been able update my maps to V5 from V4.1 using the link that was provided. I forgot to say I am using a D unit with software 3970. That is fine. But I am having problems with the points of interest. I have first tried using a SD card and loading of Ponitsofinterest file and the system when I go into set up and Nav, the my points of interest is greyed out. That is using either V4.1 or V5. I have then tried taken a copy of the Disk I burnt with V5 opening it up and deleting and replaceing the POI file, burning a image of the file using IMGburn. Then burning this image onto a disk.
The unit accepts the disk asks to load and asks if I want to install the maps. It starts nearly finshes then stops right near the end spits out the disk and asks for the nav disk. If I put the disk back it will go through the process of install then spits out saying disk error.
Then I install the normal disk and I am back at stage one.
Can anybody offer any advice or is there a nice person who can offer a V5 disk image withe points of interest in there?
PLease HELP ME i have been tryign for ages and it is driving me mad2019 MY19 Mini JCW Hatch
2016 Holden Astra RSV - Waiting for New Golf
Try first step again (loading the personalPOI.db3 via SD Card).
But delete the previous ones (personalPOI.db3) on your unit's HDD (for good measure).
In a nutshell, we are talking 118 categories & over 45,000 actual POIs.
Give it some time to digest it all. I'd say at least an hour, depending on your unit.
If still greyed out after that ... then reboot your unit and see if it POI button appears.
NOTE:
Until you get the SD card loaded POIs working, there's no point trying the delete & replace POI.db3.
As this POI.db3 file only loads the POIs into the master CATEGORIES (ALPHABETICAL) folder
This is mainly for the unit to include custom POIs in a "POIs near by" search.
In other words, it's the equivalent set I've created to help the RNS510 unit find them.
However the PersonalPOI.db3 file organises these into more logical subfolders under a folder called PERSONAL, to help users find them.Last edited by aussietig; 19-02-2012, 06:52 AM.MY11 Tiguan 147TSI (SOLD)
Soft reset:
"<" + ">" + "Info" key (far right hand side - upper)MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
Thanks for your help FJ Steve.
I have now got the disk out after a couple of goes. I am back to Version 4.1 as I am now too scared to reinstall.
No points of interest as I never got them to work either way.
So after 4 days I am no furtheer then I was before.
I think I will just give up.
I guess you could say
The german - 1
The Spikeyboy22 - 02019 MY19 Mini JCW Hatch
Did you read post #66?Originally posted by spikeyboy22 View PostThanks for your help FJ Steve.
The german - 1
The Spikeyboy22 - 0
Put a general "please help" out there to the Melbourne crew. Someone should/could be able to help.MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
Spikeyboy22, the filename and directory structure on the SD card must be perfect, otherwise the RNS-510 won't recognize the .db3 file, and hence the button will remain grey. I fell for this. I ended up exporting directly from poiinspector to SD card and then it worked fine.
I think the structure on the SD card has to be,
/personalPOI/personalPOI.db32010 Candy White Golf GTI 5Dr. Manual, RNS-510, Bluetooth, Tints, GT-CX 18 Gloss Black Rims.
Have updated most of my POI categories (especially cameras and petrol stations) via the POIDB.com website.
Total POI categories is now 119 after adding Rebel Sport.
So my links contained in post #21 are now to revised versions of both the PersonalPOI.db3 & POI.db3 (V5 map) files.
NOTE: Have not bothered to update the POI.db3 (V4.1 map) file however.Last edited by aussietig; 22-02-2012, 10:29 PM.MY11 Tiguan 147TSI (SOLD)
