I'm having AC problems in my GTI.
I've narrowed it down to the pressure sensor. I actually replaced it as I found it was not sending a signal to the AC fan control module.
Well the new one does not seem to be sending a signal either.
Basically the sensor needs to send 20-90% duty for the controller to turn on the compressor.
Since I have replaced it and still no signal I'm now doubting my ability to test for duty cycle correctly.
What is the correct way to do test with a digital multimeter?
The sensor has 3 pins.
12v+
Signal
Ground
I've been testing across ground and signal and get a flat 0%
I've been following this DIY
Fault diagnosis in the Fan Control Module - Gtivr6wiki
12v+
Signal
Ground
