Hi all,
I've just completed the change from the RCD510 to the RNS510 in my MY12 GTI. Everything went perfectly thanks to the many posts available to assist with the installation, I just thought I'd leave a couple of small notes regarding a couple of issues I encountered.
First, here is a list of the resources I used to help me out:
1. HOW TO: Retrofit an RNS510 Sat Nav System.
2. DIY - RNS510 install for MKVI (w/bluetooth and MDI)
3. DIY - RNS510 Install
4. Volkswagen RNS 510 coding when installing with a factory amplifier | my-gti.com
The physical installation is just as easy as everyone says, it really is just plug and play. All I will say is that getting the surround off from around the radio is TERRIFYING, you need to use a LOT of force to get the 6 clips off.
Once the installation was done I had to make a few small coding changes:
1. To get the unit to recognise the Dynaudio amp:
Under Controller 37 change Byte 1 as appropriate. I set mine to "05 Dynaudio Sound System" as I wasn't sure what "07 Dynaudio Sound System (BAP DSP) was!
2. To get the navigation instructions to display on the MFD, and the steering controls to work:
Still under Controller 37, enable Byte 7, Bit 7 "Communication Instrument Cluster via Operation and Display Protocol (BAP)"
After those changes the RNS510 was still not seeing the AMP, and the steering wheel controls for radio station scrolling where not working. You can tell the AMP was not working as there is no Front/Rear fader option. A reboot of the system solved the problem and it was all good from there.
I got the RNS510 LED Version C from out Lithuanian friend, delivered for $950
I got the VAG-COM cable from Dub Addiction for $299
The install took about 45 minutes. So for half the price of the factory fitted option I have more functionality (Video in Motion) and a VAG-COM cable that will be a huge value to me.
The VAG-COM cable is awesome. After the installation I started googling for other things to change. I've already fixed a "Coming Home" light problem with my Xenon's, now the world is my oyster. All I can say is, GET ONE
Next for me is the installation of an OEM reversing camera. It looks a little more challenging, but also a lot of fun.
