Hi All,
I have a 2010 Golf Wagon and I recently installed an RNS510 (which I got working perfectly) and also a reverse camera which I just can't get working and I am going crazy.
I followed the guide here: * DIY: Retrofitting a backup camera (BUC) onto a Golf/Jetta Sportwagen - VW TDI forum and Audi TDI forum - myturbodiesel.com
The problem is, that when it is in reverse, the RNS changes to show the camera, but it is a black screen and no actual output from the camera.
I have tested the constant power (12v when ignition on) and reverse power (12v only when in reverse) and both connections work fine.
I have also tested the continuity from the connector whcih goes from the RNS to the camera, and the continuity of all pins from the RNS connector to the end of the cable are fine.
The only conclusion I can draw is that the camera itself is dead, but how can I test this?
Does anyone in Perth have any VW RVC? (doesn't need to physically fit in the car, just needs to fit the connectors so I can test)
Or does anyone have any other ideas before I try to challenge the ebay purchase of the camera?
