I recently upgraded from a RCD500 to a RCD510 and while I was using the RCD 500 and AUX it worked flawlessly, sound quality was acceptable and sounded similar to the radio.
Now I have the RCD510 installed which works perfectly except for the AUX. Cable hasn't changed and was just a basically straight swap between the two units. Now when I plug in my iPhone the quality is atrocious basically all I can hear is very low sounds and doesn't even sound audible. I've turned up the volume on both the head unit and iPhone and nothing changes. I looked in the setting where there's the AUX volume/voltage and fiddled with that to no avail.
Does anyone know why this happens?
