Upgrading??? RCD310 to RCD500
  • Upgrading??? RCD310 to RCD500
    hi all, hoping someone can tell me how easy it is to replace a RCD310 with a RCD500 into a MkV Pirelli. I bought the car as an exec demo but apparently the stereo was a swap... the dealer has now sent me the original RCD500 and i would like to install this weekend... hoping this doesn't go balls up.
    All suggestions and information welcomed!!!
    Many thanks,
    Don.
    Should be a straight swap.
    In case you are not familiar with it, Maverick's brilliant my-gti website has the info you should need.
    Al..
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
      Should be an easy straight swap (plug and play)
      Will need a T20 hex head screwdriver from memory.
        thanks for the help. I will have a better look tonight although at first glance there is no information available on the RCD500???
          Originally Posted by brimway
          Hi Don this link will help.
          This post really did help!!! thanks brimway...
          Everything seems to be working well although i am now confused as the RCD500 can now be switched on with no keys in the ignition. This happens after i have pulled up taken the keys out and then hit the power button... is this the usual function of VW stereos?
          Anyone got any advice??
            The RNS510 is the same, so it's probably normal.
              thanks idle!
                Yep - radio staying on while keys are still in the ignition, and switching on without keys in ignition is system normal - all good. Will switch off after about 40 minutes anyway, really useful for leaving the kids in the car while you go off to play the pokies
                  pmsl... i hate the pokies with a passion but that is sooo funny... might have to try that out just for sh%ts and giggles!
