Hi All
Aussie just moved to France and Purchased a 2010 Tiguan with a RNS510 with the Bluetooth premium option (inbuit nokia phone, version)[ white MFD
As I needed to run an iPhone with Skype (To avoid the ORANGE 1.50 euro/min) to call Aus and others, I have downgraded the module to the latest 9W7 (UHV/RSAP AD2P / 5K0035730) from Bluewagen in Spain.
Run the iPhone with Skype for Long Distance therefore need smart phone (not through VW Nokia unit) but in europe use as normal BT/3G phone.
Will Plug VW GSM/3G aerial into Bury system 9 active cradle for iPhone(Antenna and power, no BT) to power and improve signal) (not as good as VW BT prem but will have to do)
The new unit works fine with phone books etc pairing, dialing, voice control etc, interestingly with a USA female voice.
The Issue :- my RNS510 is now a little confused with voice navigation control .
When I push the voice button on the steering wheel the system defaults to the phone , and I cannot use Nav voice commands even when in Nav mode/ screen, When a phone is paired.
It keeps requesting phone commands
Install Just plugged in the original harness that went into the "premium/ nokia" module.
DO I need to use the new harness supplied ?
Do Ineed to update te VAG-COM and with what code ?.
VAG-COM details below of original configuration
Is there someone near to Grenoble France that has exp,
would a VW dealer a helpfull or WOT ?
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 22 25 37 42 44 46 4F 52 53 56 62
69 6C 72 77
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5N0 920 871 C HW: 5N0 920 871 C
Component: KOMBI H05 0305
Serial number: 00000000000000
Coding: 110F00
Shop #: WSC 01324 020 00200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 31631A60D1AF
No fault code found.
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H20 0592
Revision: H20 Serial number: 150410F2001251
Coding: F9A27F46404603006002
VCID: 6BDFC8083303
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 7
Mileage: 19837 km
Time Indication: 0
Date: 2009.14.22
Time: 00:54:03
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 7
Mileage: 19837 km
Time Indication: 0
Date: 2009.14.22
Time: 00:54:03
-Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 C HW: 1T0 035 680 C
Component: RNS-MID H06 2760
Revision: AB001001 Serial number: VWZ6Z7K8122061
Coding: 040004020400008000
ASAM Dataset: ------------------------- ------
VCID: 2E59011CC091
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 2E59011CC091
Address 77: Telephone Labels: 3C0-035-730.lbl
Part No SW: 5N0 035 730 C HW: 5N0 035 730 C
Component: J412 8506
Revision: 00019000 Serial number: 0000330853858
Coding: 0026145
VCID: 2855F704E275
Chassis Type: 1K0
69 6C 72 77
Coding: 110F00
VCID: 31631A60D1AF
VCID: 6BDFC8083303
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 7
Mileage: 19837 km
Time Indication: 0
Date: 2009.14.22
Time: 00:54:03
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 7
Mileage: 19837 km
Time Indication: 0
Date: 2009.14.22
Time: 00:54:03
VCID: 2E59011CC091
VCID: 2E59011CC091
Coding: 0026145
VCID: 2855F704E275
