Hey all,
I've got an RCD500 in my MY08 R32 - it's got the newer CANBUS, so ready for an upgrade to an RCD510.
So I've bought an RCD510, MDI Retrofit kit, and 729W Bluetooth kit - removed the RCD500, then connected the MDI retrofit kit using the instructions.
The MDI harness install was a PITA, as I had to remove wires 9,10, 12 & 15 from the quadlock & replace them with the MDI wires, then connect the originals to the MDI.
I connected the RCD510, but it wouldn't power on. When connecting the quadlock, I get nice whirring noises from the RCD510 like it's ejecting a CD - but the power button doesn't turn it on.
So I removed the RCD510 & put the RCD500 back in - same thing.
Got out the trusty multimeter, and checked the voltage - the power positive (15) & negative (12) give me +12.4V, and the CANBUS High (9) & CANBUS Low (10) give me -11V - also checked the Display Voltage (11) & supply negative (12) also gives 12.4V.
So I removed the MDI kit & put all the pins back as originally connected, hooked up the RCD500 - and still the same bloody thing!
I've checked the Radio & Sound System fuses in the engine bay - both look fine.
I'm starting to think I should have just paid someone to install the kits!
Has anyone got any idea WTF is going on? Have I tripped a different fuse and/or busted something?
PS - Mav's site my-gti.com has been very very handy
- yet I'm still stuck
