speakers- how many and sizing in mk6 gti
  • speakers- how many and sizing in mk6 gti
    couldnt find any info with a search.
    i couldnt get a car with the dynaudio option, so i will undoubtedly go aftermarket.
    im jsut trying to gather info wrt the speakers, sizing and qty in the mk6, also, is the car amped at all? if not, what amp would be ideal
    I've got the factory dynaudio in my Golf. They come with 8 speakers in total.
    The woofers are 5.7inch and tweeters are 1inch. Pretty sure the standard system doesn't have an amp.
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
      so is that 5.7" speakers for fronts and rears? and i knew it was 8, but how are they spread out? i have a 3 dr gti, so how are the std speakers set out? 2 woofers in doors with 2 tweeters?
      rear area has 4 speakers? how?
        They have split systems 6.5 inch woofers x 4, and tweeters, approx 0.75 inch.
        Depending on what you want to do, you could run a 6.5 inch split at the front, and a 5 1/4 inch split with spacers, as they are only for rear fill.
        Although I am making an assumption that you will want a sub.
        Blaupunkt make some cost effective Plug n Play solutions as far as amps go, although I run 2 x 4 channel Alpines in mine, bridged, so effective outputting 6 channels.
        [SIZE="1"][I]2010 Mk6 GTI 3 Door - Tornado Red, ACC, Roof, Xenon, RNS510, MDI with 1TB HDD, RVC, Park Assist, BBS CK Alloy Wheels, 2 x Alpine MRV-F345 Amps, Alpine Type X 17-PRO Front stage, Type X 13-REF rear stage, 1 x Alpine Type R Sub, Alpine PKG-RSE2 Overhead DVD/Monitor
          thanks mate, so effectively, the stock system has 4 woofers and 4 tweeters. im partial to boston acoustics, and i have a jl audio sub tube that ive had for a few years which i like as its punchy for my style of music.
          ill do some research on what bostons are a good fit then
