RNS-510 no MFD functions
  • RNS-510 no MFD functions
    My car is a 2007 Golf R32 originally had a RCD500 w/ factory amp, and I have already updated to an RCD-510 with new gateway (which worked perfectly). So today I changed to an RNS-510 sourced from Lithuania on eBay. It is a Version C (non-LED). After the install the highline MFD is not showing SATNAV and audio. We scanned the car and brought back a fault that all my speakers are "open circuit" after some more digging around it appears that the car does not know it has a stereo, let alone the navigation?
    The system is working for both audio and navigation, and there is sound coming from the speakers, but no MFD menus.
    If anyone has ideas or things that I should check it would be greatly appreciated.
    2007 MY08 VW Golf MKV R32 Blue 6M 3-Door
    2006 9N3 VW Polo GTI White 5M 3-Door
    Did you update appropriately using VCDS cable? Need to ensure certain settings are selected. The symptoms you've described sound like BAP has not been enabled, but you haven't provided a lot of information.
    Once it's all working you'll also have a navigation menu on your MFD a very handy feature.
    MY10 Golf 118tsi DSG | MY07 Polo GTI
      So tried some different things last night with the VW tech again, we coded bit 7 (BAP) from 1 to 0 and after a reset of the nav I've now got navigation and audio on the MFD. YAY! The system is still showing error codes for speakers being open (even after a clear and rechecking) and the RNS is still not showing up in the vehicle devices list, but as everything is working... I'm not overly worried, lol. Will possibly get it checked out with VAG-COM and see if that has some different abilities to the VW system, but as I said not overly concerned as all is well now.
        Sounds like I would benefit from knowing this too -- see http://www.vwwatercooled.org.au/foru...ion-64251.html
        How do I enable BAP? That sounds like the solution to my problem......
