Radio Install
  • Radio Install
    I am looking to swap out RCD500 for RCD510, can anyone point me in the direction of someone (experienced) in Melbourne to do the install or at least update the vagcom coding - whatever that is!
    Surelly it would be just plug and play - simple case of pull out your old and put in the new. I doubt that there would be any vagcom required....could be wrong.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
      You may lose steering wheel controls if you upgrade.
      Also i believe you will need a canbus update if you are going from an RCD500 - RCD510.
      Might want to check out google to see if it can be done as a straight swap.
        Once you've done your research, drop me PM and we can sort something out. I've had mine (RCD300) out a couple of times (experimenting with the WD6050) and am awaiting delivery of my RNS so I will be on the tools again soon.
        Graphite Blue TDI| DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs| Full LED interior|US GLI paddle shift MFSW|Carbon Vinyl wrapped trims|Colour Coded Votex Body Kit|
          I am Melbourne bayside and can help with the coding if you need. Private, not a business
            It depends on what year you're driving. IIRC mid 08 and onwards should be fine, but anything built before that will usually require a new canbus gateway. I'm still investigating this myself as i've just purchased an RCD510 for my 06 GTI, but i've heard it may be possible to simply re-code the old gateway if you know what you're doing with a vag-com.
