Hi All,
Tried hunting for other posts on this but no luck.
I have factory MDI in my car with the USB attachment, RCD510. instead of purchasing the additional ipod cable I decided to just get an External hard drive, put all my music on that and use it instead - thinking this would work just like an ipod would.
First attempt failed miserably I just copied entire itunes library to the ext hard drive. turns out (after reading the manual) the USB attached drive must be formatted to FAT 32 partition, meaning the max I can put on there for music is 32 gig.
Fixed that up, created the FAT 32 partition, works on the first song, but its taking forever to search the folders for the next song, and skips during the tracks when I try to put it on mix play etc.
Also cannot get it to access the other folders with music in it.
So does anyone know if there is a maximum no. of folders/mp3 that you can have and have the MDI function properly? Or is it a maximum files in EACH folder?
How should i structure the files in there? just all in one single folder? at the moment they are organised in different folders depending on artist.
ALso any tips or links telling instructions on how to make playlists?
any tips/advice/suggests much appreciated! Getting pretty close to buying the ipod cable instead!
