RNS 510 - Map Version
  • RNS 510 - Map Version
    Hi - does anyone know how I can access the RNS 510 to find out what version MAP I have loaded?
    The dealer never included the DVD
    Many thanks
    Denis
    If you hold "setup" for a while it should go into a screen about your radio, keep holding and then after that it will go to "system test". From there you can select navigation and it will tell you your version.
    Map Version 7005 is version 3 which I'm pretty sure is the latest.
    If you can't access this setup screen, then there's a setting which will need to be changed in Vagcom which will then allow you.
    See here for further info on that.
    MY10 Silver R36 Wagon
    VW Classifieds Username - VWC-adrock
      For any other info on the RNS 510 and help with other VW related issues you might like to visit my-gti.com
      Russ
        Hi adrock
        Thanks very much. Made the changes via VAGCOM and confirmed I have Map Version 7005.
