Radio keeps playing after ignition key is removed.
  • Radio keeps playing after ignition key is removed.
    I've just noticed in our Golf5 that radio keeps working for about 1-2 minutes after key is removed from ignition and doors can't be locked until it switches off.
    It's too dark to investigate now, will connect VCDS tomorrow and see if it gives any clues?
    I just wander if someone else had this problem before?
    Any hint appreciated?
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
    Update:
    Just connected VCDS found 1 fault 01303 -Telephone Transceiver (R36)
    004 - No Signal/Communication
    Cleared the code and everything is back to normal.
    Will see if the problem comes back.
