Hi im installing a rns510 into a mk5 golf gti 2006 model what cables will I need to get it working correctly? The origanal cd player I have is a rcd300. and is there anything elese i need to do to get it working or is it a direct plug in?
help replacing a rcd300 to a rns510
You need a new antenna connection, possibly (probably) a new gateway, you may also have an external diversity unit that needs work and that's about it.Originally posted by ma160802 View PostHi im installing a rns510 into a mk5 golf gti 2006 model what cables will I need to get it working correctly? The origanal cd player I have is a rcd300. and is there anything elese i need to do to get it working or is it a direct plug in?
Upgrading 2nd generation radios (RCD 300, RCD 500) to 3rd generation (RCD 210, RCD 310, RNS 310, RCD 510) power drain issue
Upgrading 2nd generation radios (RCD 300, RCD 500) to 3rd generation (RCD 210, RCD 310, RNS 310, RNS 510, RCD 510) antenna adapter
CAN bus gateway removing, installing and upgrading - Volkswagen Golf
If you have the CD changer or Aux in you will need to do this
CD changer audio sound quality problems after changing head unit
Auxiliary input audio sound quality problems after changing head unit
Diversity info (should be a box under the drivers seat)
Aerial Information for Volkswagen Golf
Volkswagen aerial selection control unit / diversity informationLast edited by Maverick; 17-06-2010, 11:07 AM.website: www.my-gti.com
thanks for your reply maverick i have checked my build date and its july 2006 and The part number of the rns510 that i have bought is 1TO 035 680 B. What antenna upgrade do you recommend? is there a kit that i can buy? by looking at the link provided i think i have the setup of Aerial systems 06.05 > (going off the build date) with the stand alone rcd 500 radio system setup.
im hoping that my rns510 comes with firmware ver 1100 and that i wont have to change the gatway. is it only with the new 2660 firmware you need to change the gateway? and is it worth upgrading to the newer firmware?
and regarding the external density unit , will this cable work? becuase i bought one last week ? and how do i install it ? do i need the bypass?
