Originally posted by pikii
View Post
MFD2 (DVD Based) Aux Input
Google them and you'll find them. And yes the CD version works on the DVD unit.website: www.my-gti.com
Thanks pretty much what I do, use an iPhone as a media centre, it will play ripped movies, music, podcasts, picture slide shows, even stuff streamed from the net - as long as it uses the Quicktime API, it will output thru the Apple cable to the Sat Nav. The video improved lately when I fitted a new battery - go figure!Originally posted by Tezzasta View PostActually by 'TV Free' I mean 'Video in Motion'. That term seems to be used by the Europeans. Both the items shown only provide the Video in Motion function. You still need to install a video/audio source for both of these. The difference between the two is that the first device plugs into the CD changer aux video/audio input and the other appears to use other inputs on the main square plug.
I am trying to find out if there are any advantages/disadvantages between the two. I most likely would be connecting a video ipod, mainly for music but the occasional movie/music video etc. I know the quality most probably will not be the best but do not expect DVD quality etc..
Macad, just to clarify, does this interface plug into the AUX plug on the back of the MFD2 or the CD changer plug (like the VW ipod connector)??Originally posted by macad View PostThanks pretty much what I do, use an iPhone as a media centre, it will play ripped movies, music, podcasts, picture slide shows, even stuff streamed from the net - as long as it uses the Quicktime API, it will output thru the Apple cable to the Sat Nav. The video improved lately when I fitted a new battery - go figure!
So to use this, you select AUX on the MFD2 correct?
Sorry to be a pain, I just want to order the correct one this time to use my iphone as you do....
Yep, plugs into the back with is solely for the AV/Aux which is accessed from the button on the front of the MFD2 - I still have the CD changer working in the armrest.
The trick I found was to NOT to recharge the iPhone while using video thru AV - reduced alternator whine greatly. Send me your email if you need any more info - I'm not on here much usually over on the Australian section of the Golfmkv forum.
