Is an 2.0FSI golf MkV prewired so that one can simply install an amp beneat one of the front seats, or would one have to lay signal and speaker cables from behind the headunit and to the speakers?
FSI wired for below-seat amp?
Originally posted by iampivot View PostIs an 2.0FSI golf MkV prewired so that one can simply install an amp beneat one of the front seats, or would one have to lay signal and speaker cables from behind the headunit and to the speakers?
An easy alternative is the Blaupunkt P'n"P amps.
Upgrading the audio with the stock headunit without the factory amplifier
website: www.my-gti.com
That's the oem amp, these are designed for retrofitting and come with harnesses, no cutting or anything required all plug and play. They fit about 100 cars as well.website: www.my-gti.com
So it is only the OEM amp that comes plug and play? I've got an old amp from our old 3 series that I want to use in my car..2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
OK, the amp is a 5K0 035 456 - Blaupunkt 8 channel amplifier, manufactured May 09, HW H06, software 0316. No wiring harness, but also with the metal bracket to mount to the floor of a Passat (or Golf V or VI, same part number) 1K0 035 883, and the black plastic piece to cover it all up under the front of the seat - 1K0 971 813 (also the same part number for a Golf).
The amp is one of these: http://www.worldimpex.com/parts/genu...r_1754088.html
Only thing is I have no cables like I said, and I have no wiring diagram for it...
Originally posted by Swallowtail View PostOK, the amp is a 5K0 035 456 - Blaupunkt 8 channel amplifier, manufactured May 09, HW H06, software 0316. No wiring harness, but also with the metal bracket to mount to the floor of a Passat (or Golf V or VI, same part number) 1K0 035 883, and the black plastic piece to cover it all up under the front of the seat - 1K0 971 813 (also the same part number for a Golf).
Volkswagen factory amplifier details and pin assignments
Originally posted by maca View PostSo it is only the OEM amp that comes plug and play? I've got an old amp from our old 3 series that I want to use in my car..website: www.my-gti.com
